Author Topic: So what 'appened was...  (Read 3123 times)
swiss
  • Southampton
« on: 08 June 2009, 17:39:25 »
OK, so new brakes, filters and an oil change on the 2.5TD auto. Took it out for a good thrash on the M27 en-route to the MOT station.
I was in the fast lane and the van in front of me slowed, then sped up again. Partly out of wanting to keep the revs up, partly out of habit with the manual, I dumped it down a gear.
Next thing I know, the tacho is off the scale and the throttle is refusing to play. I ninja lane-changed to the outside but couldn't get the speed back up.
So I threw it in to the hard shoulder with me hazards on and went in to fault diagnostic mode. I saw the temperature gauge was way past the red line and reasoned the car had engaged limp mode.
I struggled on to the MOT station and sure enough, it passed the emissions test. However.
As I left, the temperature sprang right back up. I pulled in to a park and gave it half an hour to cool off. When I started the electrics, the gauge read 90 or so, perfectly acceptable. But sure enough, once I pulled away it went right to the line again.
Having had it outside the house cooling for three hours, I topped up the water (the computer was complaining and, yes, the level was pretty damn low). Took it off for a test drive at 30mph and... the temp hit the red line in under two minutes and car started limping again.
So, what have I done? No leaks apparent, cooling fans kick in just fine... did I kill the thermostat? Please, God, tell me I didn't  :|
Thanks
Tom
markey mark
  • SLady bitshorpe north lincs
Re: So what 'appened was...
« Reply #1 on: 08 June 2009, 17:42:42 »
water pump  :y
swiss
  • Southampton
« Reply #2 on: 08 June 2009, 18:29:10 »
Oh God damn it.
OK, thanks markey. So now what? There's no Haynes for this model and no how-to in the maintenance sub-forum.
Anyone able to walk me through it please?
markey mark
« Reply #3 on: 08 June 2009, 18:30:35 »
carnt walk you bud never done one but iirc there not too bad  :y
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #4 on: 08 June 2009, 18:34:54 »
water pump  :y
Yup Water pump
It's on the shaft that carries the Viscous Fan (LH thread BTW)
Quite an easy job, drain the radiator & block first
Replace with one that has Brass vanes
Pitchfork
swiss
  • Southampton
« Reply #6 on: 08 June 2009, 20:22:59 »
Wow. That's cool, thanks. And I always thought PDFs were sent by the devil to try us...
gazsomega
  • midlands
    • 2.5 Opel estate
« Reply #7 on: 08 June 2009, 21:49:33 »
that a great haynes manual lol
Used  to have  two v6 and they roared
Now got 2.5 to Opel
James Q
  • Colchester
« Reply #8 on: 08 June 2009, 22:08:25 »
let us know how you get on bud?
swiss
  • Southampton
« Reply #9 on: 09 June 2009, 14:54:43 »
Pump and o-ring on order, 2-3 days though :(
Checked with the local stealer, out of curiosity, and they'd want two hours labour at 150+. So, um, it'll be a DIY job then :)
Would you guys appreciate piccychurs for the guide section? They'd mostly be of stripped threads and bleeding knuckles, but if it'd help...
GastronomicKleptomaniac
  • Teesside (the nice bit)
    • 3.2 plod, 2.6 MV6, etc
« Reply #10 on: 09 June 2009, 16:32:58 »
Guides are always appreciated. :y
Pitchfork
« Reply #11 on: 09 June 2009, 19:49:38 »
Just be careful the parents don't find out! ;D
swiss
  • Southampton
« Reply #12 on: 09 June 2009, 23:15:48 »
Sound advice.
By the way, I unclipped a sensor to get the oil filter out, as described in the how-to. Pretty sure I forgot to plug it back in. What does this sensor do and could it have any bearing on this problem?
swiss
  • Southampton
« Reply #13 on: 10 June 2009, 13:32:03 »
Hi guys. Made a start on removing the old pump, so hopefully when the new one turns up I can just slap it in and put all the other bits back on.
Question: I'm trying to remove the rad and IC hoses but they're secured with a type of clip I've not come across before. Do I just need to squeeze it? Can I do so by hand or will I need something to compress it?
Thanks
Tom
« Reply #14 on: 10 June 2009, 13:42:53 »
molegrips work well
there are special hoseclip pliers that work as well.
but yes, self gripping clips, just squeeze tabs together to release.
« Last Edit: 10 June 2009, 13:43:25 by jimbob »
