Author Topic: Omega 3.2 - Coolant / Water leak - 2nd opinion?  (Read 3711 times)
Mat3200
  • Bisley (nr Woking) Surrey
« on: 08 June 2009, 14:37:07 »
Hi all - I have a Omega 3.2 V6 2003 - 68000 Miles covered.
In the last few of months I noticed the coolant water level was dropping in the header tank only a little but it would need topping up every 6-7 weeks. I got it to my independent garage who looks after it and they said that there was coolant leaking from 'the back of the heads' and it would be un economical to try and repair it.
Last week I noticed that all the coolant water had gone after topping up and driving a few miles the car was fine until I turned off the engine then loads of water would pour out of the bottom of the engine (rear section).
It looks like the end of the road for this car :-( as again my garage says that it will cost far more than the car is worth to repair and is a big job.
My question to you all is it really the end of the road is there anyway this car could be saved?
Thanks
Mat
ScottieMV6
  • Swinton, Manchester
Re: Omega 3.2 - Coolant / Water leak - 2nd opinion?
« Reply #1 on: 08 June 2009, 14:39:33 »
Favourite in that area is HBV (Heater Bypass Valve), common for them to go.
Part is around £30 from Vx and it takes about an hour to change. Definitely not cause to scrap the car.
Alternatively could be the oil cooler plate leaking - again not a huge job to do yourself.  :y
I'd rather be scared to death than bored to death!!
markey mark
  • SLady bitshorpe north lincs
« Reply #2 on: 08 June 2009, 14:57:03 »
fill your profile in so we know were you are bud  :y
Mat3200
« Reply #3 on: 08 June 2009, 15:16:34 »
This would be good news :-)
Any ideas whereabouts I can get these two possibles for the leak looked at in the Woking (Surrey) area?
Thanks Mat
bob.dent
  • Hertfordshire
  • Drives better than an Omega
    • Mondeo 2.0TDCI Estate
« Reply #4 on: 08 June 2009, 15:34:04 »
Thanks Mat
Any decent independent garage worth their salt should be able to do the HBV for you. My local garage did mine for around £95 including coolant. :y
VX1
  • Reading, Berkshire
« Reply #5 on: 08 June 2009, 16:06:08 »
This will be your HBV. Easy job to do yourself, there is a guide on here.
Paul :y
Vx Trade club card holder
Halfords trade card holder
« Reply #6 on: 08 June 2009, 16:29:23 »
Paul :y
Everyone said that about BazMV6's, which had exactly the same symptoms - but the cylinder heads are currently sat on my floor!
Head gasket failure, while uncommon, happens due to poor coolant maintenance at some stage in the cars life.
It COULD also be something silly like the HBV etc -
What you need to do, is take the inlets all out, and pressure the coolant system, and try to spot the leak....
« Reply #7 on: 08 June 2009, 18:48:22 »
Yes, could be HBV, would expect a garage to spot that.
Could be core plug(s)
Could be Head Gasket.
Mine also has a (serious) leak, which is one of the hard 2 above.
« Reply #8 on: 08 June 2009, 20:30:09 »
some numpty garages about mate. With your car and its mileage, even if the hg is gone it is most definately worth repairing. But most on here would get it done through this community, either diy or some of the numerous competent soles on here. We have all encountered this sort of diagnosis and its 99.99% been bo**ox. Ignore them.
With the rate you describe your coolent loss its more than likely hbv . But there are other common causes as said. If it was me, i would just change the hbv anyway as they fail regularly and you will save some of that risk later on by swapping it out. If it still leaks then look further. Difference is by the sound of it you would rather pay for it to be done. So your cash your choice.
Unless someone near you is willing to have a look/do the job for you .
The job itself is simple in theory, the problem is access and bloody awkward clips. But an hours labour should see it done at any garage.
« Reply #9 on: 08 June 2009, 20:41:12 »
As mark would say - don't change anything without a firm diagnosis - it introduces more unknowns.
You need to get that plenum off and pressurise the system to look for a leak (from cold).
« Reply #10 on: 08 June 2009, 20:54:58 »
and if it is the hbv it will double the bill/time/effort involved. If its not then it will quite possibly save a future failure. With the rate its coming out then should be easy to diagnose just by looking. He does not have your experience dont forget james. :-)
« Reply #11 on: 08 June 2009, 21:00:44 »
When it's HBV - you can often tell by running the engine and feeling around that area.... :y
teddog 34
« Reply #12 on: 08 June 2009, 21:19:44 »
Had the very same problem with mine , changed hbv myself and im no mechanic, if you get uner your car behind the drivers front wheel and look up into eng bay you can see the hbv . Whilst still under car get someone to alter the heater control from hot to cold and see  if there is any leakage.. The jobcost me thirty quid and an hour of my time job well done
« Reply #13 on: 08 June 2009, 23:07:39 »
99% it will be HBV at that age / mileage.
IIRC, the 3.2 has metal head gaskets so unlikely to fail in the way composite ones do.
I'm not far away and could give you a hand but I'm tied up for the next couple of weeks, I'm afraid. :-/
« Reply #14 on: 08 June 2009, 23:33:28 »
Drop me a pm if you need me to come over to woking and look at it. But im on late shift all week, however i am in Espom Sat evening so will be almost passing your door. But you may well need the car before then i guess?
we are all too honest. Should have said the garage was right and he should sell it to ME for 500 smackers. :-) (joke.... Ok bad joke....alright, alright ill get me coat)
