Author Topic: calibrating temperature guage if its "out"  (Read 1045 times)
Simon_Omega
« on: 13 June 2009, 18:12:03 »
if your temp guage displays 100 when its at 95 in the tank, is there any way of making an alteration to the calibration set point? or if so, does it need the old tec 2?
Simon_Omega
Re: calibrating temperature guage if its "out"
« Reply #1 on: 13 June 2009, 18:12:39 »
reason being, i have a car thats running hot, except, it isnt running hot at all, it runs perfectly.  and the temp is out.
« Reply #2 on: 13 June 2009, 18:14:54 »
pretty sure you can TechII the gauge, The Boy is your man!  :-?  :y  :y  :y
semisheen
  • Chesterfield
« Reply #3 on: 13 June 2009, 18:16:20 »
Could it be just the sender that is out ?...
Not that im an expert about this sort of thing
« Reply #4 on: 13 June 2009, 19:56:06 »
Hotel21's old car had this issue.
can be the instument panel has the wrong varient coding.
Tech2 required.
« Reply #5 on: 13 June 2009, 19:59:29 »
Worth getting a tech2 on it to see what engine ecu says temp is, and what instrument says temp is, that should give some clues.
Ensure variant coding on panle is right
« Reply #6 on: 14 June 2009, 11:32:04 »
Simon - the reading needs to come from the coolant temp sensor area near the coolant bridge - doubt you'd get an accurate reading from the header tank......
