Author Topic: Could this be a gear box breather ???  (Read 2381 times)
Mike_T
  • Trimley Nr Felixstowe
« on: 18 June 2009, 19:16:58 »
Hi, thanks for your help with the HBV job done and no leaks now.
Whilst doing this I found a rubber pipe at the back of the engine going nowhere its about 13mm o/d and 6mm i/d has it got a home or should it just be left in space ?? is it a breather as the other end  seams to come from the auto gear box
Hope you can help again  :-[
Mike.
Re: Could this be a gear box breather ???
« Reply #1 on: 18 June 2009, 19:20:35 »
Sounds very likely! No picture then?  ::)  ::)  ::)  :y
MutantCav
  • Gainsborough
« Reply #2 on: 18 June 2009, 19:20:41 »
Yes mate, auto box breather pipe...goes nowhere :y
Richard A
  • Aldridge, West Midlands
« Reply #3 on: 18 June 2009, 19:21:34 »
Yes it sound as if it's the autobox breather and yes just leave it open ended.
regards
richard a
richard a
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
« Reply #4 on: 18 June 2009, 19:22:14 »
I do believe its a breather and should be left alone. I recall reading it a couple of times here on the forum.
 ( If I'm wrong the guys will correct me ;))
He who brakes Looses
To old to die young
« Reply #5 on: 18 June 2009, 19:29:57 »
sounds like it :)
over50now
  • Hertfordshire
« Reply #6 on: 18 June 2009, 20:19:31 »
As above.
Believe discussed by several OOFers about March time.
IAM & ROSPA Gold Grade driver
Mike_T
« Reply #7 on: 18 June 2009, 20:44:49 »
Hi and thanks again, you all deserve a medal awarded for the peace of mind you have given me,   :y
Mike.
« Reply #8 on: 18 June 2009, 21:20:47 »
It should be left attached and unblocked, but secured "up high". If it were to fall down it might just syphon all your gearbox fluid out !!!!
 :D :D :D :D
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #9 on: 18 June 2009, 22:24:36 »
Hey..A thought.  Can we top up the box oil through the breather pipe...?
« Reply #10 on: 18 June 2009, 22:38:20 »
Theres a thought,would be interested to know the answer. :-/
« Reply #11 on: 18 June 2009, 22:46:37 »
How would you know the level ??? before, after and during ???  Too much is just as bad as too little ... :(
« Reply #12 on: 18 June 2009, 22:46:44 »
I would imagine the answer is yes (but don't quote me on that) but I don't see any real benefit as you still need to get the level plug out to know when you've put enough in :-? :-?
[edit]
Oh... And it'd be a royal PITA trying to get more than a thimble full of fluid down a pipe that size :o :o :o[/edit]
« Last Edit: 18 June 2009, 22:47:48 by Lazydocker »
semisheen
  • Chesterfield
« Reply #13 on: 18 June 2009, 23:29:35 »
where would the breather be usually on a TD ?
if i can find it ill tell you if you can fill it there or not tomorow
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #14 on: 19 June 2009, 01:14:52 »
Rats !  So its possible but you run a huge risk of over filling then...Darn.
