Author Topic: Rumbling rear wheel bearing !!  (Read 992 times)
Big_Roger
  • Southampton
« on: 19 June 2009, 00:35:08 »
Hi all,
I have decided that it is time to do something about the rumbling on my near side rear wheel bearing.
I have looked through the maintenance guide and FAQ, but no one seems to have had this problem.
Has anyone done this job ? and got any info or tips? Cost of replacement bearing?
Regards
Roger
Be patient ! Something else will go wrong for you to fix if you wait long enough !!
Re: Rumbling rear wheel bearing !!
« Reply #1 on: 19 June 2009, 07:53:30 »
the saloon ones are about 20 on tradeclub, estate nearer 40 sorry.
It can be not too bad, or it can be a bastard if the bearing is seized in.
On mine we had to remove trailing arm, apply lots of heat and liberal use of sledgehammer, but this has been one of the hardest ones.
« Last Edit: 19 June 2009, 07:53:58 by jimbob »
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #2 on: 19 June 2009, 16:51:36 »
Bought mine from autoparts/partco, about £18 IIRC. Can be bit of a job without proper tools, local garage refused to even try, but then they can hit it with a sledgehammer.
Al
If it aint broken, you aint trying hard enough
Page created in 0.03 seconds with 17 queries.
