Author Topic: is it a 3.0 or a 2.5,2.6  (Read 1683 times)
JK
  • EASINGTON LANE
« on: 23 June 2009, 07:24:10 »
Hello again ,well i have been bitten by the omega bug , my future sun in law said he would like an omega , and so he bought mine [without tax and test ] and i have bought another one with tax and test, The problem lies with the identity of the engine , it was advertised as a 3.0 elite,but ,when i lifted the bonnet ,the plenum chamber is smaller than the one on the other 3.0 engine , the one with the smaller plenum is an N reg , i just wonder if someone has put in a 2.5 or 2.6 engine, or were the older models made with the smaller plenum chamber,it dose have a full and current service history to 83k , the car is showing 90k at the moment . If it is a 2.5 or 2.6 what type of power diference will it be and also what about the fuel consumption,any help will be well recieved --thanks JK
i'm not fat,i just have a slipped chest
Dazzler
  • Haverhill, Suffolk
Re: is it a 3.0 or a 2.5,2.6
« Reply #1 on: 23 June 2009, 07:52:53 »
It wont be a 2.6 as that is DBW and coil packs.
It will be a 3.0 as the early ones had a short plenum, only the later ones had a long plenum fitted ;)
JK
  • EASINGTON LANE
« Reply #2 on: 23 June 2009, 07:54:03 »
thanks for that , i feel a lot better with that answer--JK
« Reply #3 on: 23 June 2009, 08:08:56 »
Yes, 3.0 Plenum can be large or small.  Wouldnt worry.
MutantCav
  • Gainsborough
« Reply #4 on: 23 June 2009, 08:14:32 »
Presumably you had a newer car before as the longer plenum came in for the 3.0 late 97 with the introduction of the mini facelift versions...
You can put a longer plenum on your older 3.0 if you want :y
JK
  • EASINGTON LANE
« Reply #5 on: 23 June 2009, 08:28:16 »
i might just do that thanks again--JK
JK
  • EASINGTON LANE
« Reply #6 on: 23 June 2009, 08:30:20 »
Is there any power difference in the different size plenum chamber,or, would i gain anything by changing it ,thanks JK
« Reply #7 on: 23 June 2009, 09:19:54 »
Same power, 'snooped' or long plenum gave 3's better air intake.
The 2.6's actually did not need the extended plenum but had to cause of DBW system
ngrainqey
  • rotherham
    • BMW E92, 2.6 CD F/L Est.
« Reply #8 on: 24 June 2009, 17:39:57 »
as tunnie says... think its slightly better torque or something on the longer plenums
V8!!!!
