Author Topic: 2.2 really revving before changing gear when cold  (Read 1612 times)
jampot1979
  • stevenage, hertfordshire
« on: 26 June 2009, 14:17:41 »
Hi,
When I drive the omega from cold, it seems to rev quite high before the auto box changes gear. After a couple of minutes it sorts itself out. Sometimes also it takes awhile to start the car.
Any ideas?
Re: 2.2 really revving before changing gear when cold
« Reply #1 on: 26 June 2009, 14:21:52 »
they do hold the gears for longer from cold, for quick warm up cycle, should only be for a minute or so
Welung666
« Reply #2 on: 26 June 2009, 14:22:06 »
You need to get the codes read really. They do rev a little ligher when cold to aid the warm up, could be a failing MAF causing the cold starting problem hence needing any stored codes read. HTH :y
Proz
  • Largoward , Fife , Scotland
    • Omega-less now :-/
« Reply #3 on: 26 June 2009, 18:54:04 »
Mine will rev up to 3 or 4 thousand before changing gear after a cold start even driven very gently ... i belive its totally normal  :y
jimmas
  • stevenage, herts
« Reply #4 on: 26 June 2009, 19:04:24 »
yep normal james, mine does it, it is to help heat the cat up on a cold start
