Author Topic: Auto gearbox on 3.2  (Read 774 times)
pscocoa
  • Sandhurst Berkshire
    • Volvo V90 D5 & Grandland
Auto gearbox on 3.2
« on: 27 June 2009, 12:45:30 »
Clarification please - I did pedal test and got 1 flash followed by 7 then 10 then 10 which is Service Required for Auto Transmission as per OOF Maintenance Guide.
Is the gearbox fluid supposed to be changed regularly and at what intervals - 1 - official 2 - recommended.
Took the Signum in today for new rear discs and pads and Trade Club card worked well - got pad and disc set for £60 - thanks to this site for the heads up on the card - first time I have used it even if on wrong vehicle!!
« Last Edit: 27 June 2009, 12:46:26 by pscocoa »
Re: Auto gearbox on 3.2
« Reply #1 on: 27 June 2009, 12:47:04 »
Always worth changing the atf, but you need to get gearbox ecu codes read
pscocoa
« Reply #2 on: 27 June 2009, 12:50:32 »
Thanks - my idea was that if it is a scheduled tf change I would have it done rather than just check level and have codes read.
I will have it changed anyway I think as it is at 84000 miles.
