Author Topic: how to change a thermo stat  (Read 3971 times)
kingplym
  • camden, hatfield, st.neots
  • sports on, kick down
« on: 26 June 2009, 21:58:27 »
can someone please link me to the change a thermostat  page, i have had a tipple and cant seem to find it ::) ;) :y
« Last Edit: 26 June 2009, 22:08:09 by kingplym333 »
i am willing to trade my electrical labour for parts work etc
Re: how to change a thermo stat
« Reply #1 on: 26 June 2009, 22:02:01 »
Easiest way is to take it to the "Dynamic Duo" ... and watch them struggle !!!
I was really glad it was them doing it, not me, when it wouldn't go back together the way it should ........ :)
Job was done, at the agreed price, in a very professional manner. I would recommend them to anyone .. :)
« Reply #2 on: 26 June 2009, 22:12:48 »
EGR nut off and EGR valve unplugged
Rear plenum breather hoses off
Throttle and cruise cables off
Rear multiram connector and vacc line off
Idle control valve and connector off
2 x Front air intake hoses off
2 x passenger side cable tray bolts off
4 x plenum bolts out, and remove air intake plenum
6 x torx bolts removed for upper manifold. E12 socket required and mid length extension bar.
Fuel injector connector off (large connector at rear of engine, connected to upper manifold).
Lower inlet divider off (more torx bolts!)
Rad hose off the coolant transfer pipe.
Bolt on the front side of the 2-4-6 head removed, (bolt that holds the dipstick tube, lifting eye and coolant transfer pipe).
Coolant transfer pipe seperated from stat housing, and removed.
Stat housing removed, with 2 torx bolts.
Re-fitting is reverse of removal, just ensure all mating faces are clean. Plenum bolts 6nm, ensure all O rings are kept.
It's a job that can be done DIY and will take a couple of hours  :y
« Reply #3 on: 26 June 2009, 22:14:14 »
Obviously, replace O rings on the front link pipe at the same time, you'll need to get these seperately
kingplym
« Reply #4 on: 26 June 2009, 22:30:20 »
thanx boys but i really needed a pic cos im not sure there is a thermo housing or stat to be honest? :-/
Martin_1962
« Reply #5 on: 26 June 2009, 22:40:51 »
Take off cam belt, take off backing plate.
Break lug off pipe, saw through dip stick bracket, remove head, angle grind off bastard bolt.
Mine was horrible to do
kingplym
« Reply #6 on: 26 June 2009, 22:42:35 »
w ww w w ww ww w w ww wwhat!!!!!!
surely you jest
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #7 on: 26 June 2009, 22:45:58 »
Spent about hour trying to remove hose from housing and ended up changing the stat with it still partially fitted. Took a while but at least the hose DROPPED OFF when I went to refit the securing bolt for it. Missus thought I lost a hand by my stream of queens english.
If it aint broken, you aint trying hard enough
hotel21
  • The Kingdom of Fife
« Reply #8 on: 26 June 2009, 22:54:59 »
surely you jest
Probably not but, there again, he always has to do things his own way rather than the way that the rest of the world does, as per the guide on here....   ::)
kingplym
« Reply #9 on: 26 June 2009, 23:32:37 »
ah yes hotel 21 were is the guide on here please i need picture as i am only a loley sparky
thanx :y
hotel21
« Reply #10 on: 26 June 2009, 23:34:53 »
thanx :y
how about this??
http://www.omegaowners.com/forum/YaBB.pl?num=1229464812
step 16 is the one that caused Martin the grief, I think.  Affectionately known as the B'astard Bolt.....  Loads of fun and amusement for the over 12's....   ;D
« Last Edit: 26 June 2009, 23:36:37 by hotel21 »
« Reply #11 on: 26 June 2009, 23:43:20 »
thanx :y
how about this??
It was watching the ever so slightly smug grin on a certain gentlemans face as it came out oh so easily ....  but when he tried to refit it ... now that was a different story ........  :)  he then had to earn his fee ...... :)
kingplym
« Reply #12 on: 26 June 2009, 23:44:24 »
just hwat i thought i dont have that silver housing in front of my inlet manfold. is that a prob> :(
al brown
  • alton, hants
« Reply #13 on: 27 June 2009, 00:19:49 »
If you want to come over and diagnose my suspension pump fault I will help with your stat.
Al
kingplym
« Reply #14 on: 27 June 2009, 01:54:18 »
oh come omn i must ve the only drunk person on sete
