Author Topic: Plenum  (Read 2589 times)
Dave Elite
  • Ellesmere Port
Plenum
« on: 03 July 2009, 20:06:53 »
Hello. Is it true that one of the 4 rubber tubes on the top of the plenum should be left disconected? If so which one? thanks Dave
Dave Elite
  • Ellesmere Port
Re: Plenum
« Reply #1 on: 03 July 2009, 20:07:27 »
Sorry, on an auto
Re: Plenum
« Reply #2 on: 03 July 2009, 20:08:25 »
I dont think so!
there is one extra rubber pipe on auto's from the autobox which vents to atmosphere if thats what you are thinking of?  but thats in addition to the 4 normal.
Dave Elite
  • Ellesmere Port
Re: Plenum
« Reply #3 on: 03 July 2009, 20:12:15 »
I dont think so!
Thanks for that. Its just that I have read on here that you should not connect the autobox pipe. Where would you be able to connect it to by mistake?
Re: Plenum
« Reply #4 on: 03 July 2009, 20:23:09 »
I dont think so!
There should be 4 pipes and the auto box breather which doesn't connect to anything
« Last Edit: 03 July 2009, 20:23:42 by Elite_Pete »
Dave Elite
  • Ellesmere Port
Re: Plenum
« Reply #5 on: 03 July 2009, 20:25:54 »
I dont think so!
Thanks. Is the auto box pipe easy to spot? And what would happen if it was connected?
Re: Plenum
« Reply #6 on: 03 July 2009, 20:27:57 »
I dont think so!
Short term, probably nothing but I would check the gearbox oil level.
MutantCav
  • Gainsborough
Re: Plenum
« Reply #7 on: 03 July 2009, 21:05:26 »
What would you connect it to as its designed not to connect to anything??
Dave Elite
  • Ellesmere Port
Re: Plenum
« Reply #8 on: 03 July 2009, 22:05:13 »
I've never seen the tube and dont know what it looks like.
MutantCav
  • Gainsborough
Re: Plenum
« Reply #9 on: 03 July 2009, 22:09:26 »
It runs from a short angled pipe from the front of the auto box...
Re: Plenum
« Reply #10 on: 03 July 2009, 23:21:37 »
i dont beleive its long enough to reach the breather connections....is it?
Dave Elite
  • Ellesmere Port
Re: Plenum
« Reply #11 on: 03 July 2009, 23:37:28 »
Thanks for all the help. I just wanted to make sure.
spaceraceuk
  • Ipswich, UK
Re: Plenum
« Reply #12 on: 04 July 2009, 09:58:52 »
No its not very long, certainly no tlong enough to reach the engine bay. After some work on the auto box on mine they didn't tuck it away properly and as I drove off I heard an odd scraping sound. Got out and checked underneath and there was the pipe hanging down and dragging along the ground, only just touching it though.
I didn't know what it was at that point so slightly panicked, but when I went back they explained what it was and tucked it back into position..
- spacerace -
RichardH
  • Ireland
Re: Plenum
« Reply #13 on: 04 July 2009, 11:50:58 »
Hi Dave,
Here is a picture of the breather tube on my car if it helps.
Re: Plenum
« Reply #14 on: 04 July 2009, 15:22:39 »
Yep
