Pages: 1 [2] 3  All   Go Down
Author Topic: Airconditioning service at vx dealers  (Read 5222 times)
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
Re: Airconditioning service at vx dealers
« Reply #15 on: 29 June 2009, 11:13:54 »
Ok. On saturday i took the car to a hifi installer to install a stereo for me. All  went well, but they had such a hard time removing the  CDR 5000 and they had to  dismantle the whole climate panel and  put it back.
could they have plugged something in the wrong place..hence causing the problem...
« Reply #16 on: 29 June 2009, 11:42:39 »
Very possible!!
« Reply #17 on: 29 June 2009, 11:56:04 »
Ahhhha
they must have disconnected something
either electrical or physical, are there small joining levers they could have disconnected  >:(
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #18 on: 30 June 2009, 10:29:04 »
I drove the car yesterday from work and AC has been working superb. I really don't know what happened yesterday morning as it was blowing warm air.
Today morning it was still in top form.
« Reply #19 on: 30 June 2009, 10:30:16 »
wind must have been in the wrong direction!
hope its not the start of an intermittant problem  :-/
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #20 on: 30 June 2009, 11:47:13 »
One thing could be that if it was very warm and Sunny then the sun sensor would have been giving reading to make it run colder quicker to cool the inside of the car down. I find this to happen on mine.
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #21 on: 01 July 2009, 10:51:34 »
You were absolutely spot on. The same issue has cropped up again. Anything above 17 degree and the A/C blows warm air. Very irritating in this weather. So basically if i want A/C cool air for now i have only keep the temprature at 16 degrees or below.
I spoke to the guys at Wheels in motion and they have asked me to take the car back for them to have a look. Could be some leak somewhere they said.
Fingers crossed. Really not keen to visit my local dealer..They always seem to get the diagonistics wrong and i always pay for incompetence!!
« Last Edit: 01 July 2009, 10:52:33 by kumamoto »
« Reply #22 on: 01 July 2009, 11:31:14 »
Sounds to me like one of the blending flaps is stuck / disconnected. Over a certain temperature the climate panel will open the heater valve to allow coolant into the matrix and use the blending flap to control temperature. If the flap is stuck on "hot", it will result in a sudden increase in temperature.
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #23 on: 01 July 2009, 13:19:54 »
Where are these blending flaps ? Could the regassing guy have done this accidentally ?
« Reply #24 on: 01 July 2009, 13:22:27 »
no, a regasser just connects to valves in the engine
Replacing a stereo is much more likely.
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #25 on: 01 July 2009, 13:53:21 »
ok thanks.The radio installer had such a hard time removing the stereo that they took the whole climate control panel off. He must have re-connected it wrongly. I need a mechanics who knows miggys. Can anyone recommend a mechanic?
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #26 on: 01 July 2009, 13:54:40 »
But then again if he re-connected it wrongly...why did it work perfectly yesterday and failed today? It laso failed on monday.
« Last Edit: 01 July 2009, 13:56:30 by kumamoto »
sjc
  • Alloa, Scotland
    • Ultra-dull Audi TDi
« Reply #27 on: 01 July 2009, 14:23:23 »
Did you perform the reset procedure as mentioned above?
« Last Edit: 01 July 2009, 14:23:50 by sjc »
Kumamoto
  • Mombasa, Kenya
    • Omega 2.2
« Reply #28 on: 01 July 2009, 16:47:55 »
Yes, i did that and it worked fine yesterday. Then it started playing up today again.
sneakypenguin
  • Birmingham
  • Xbox gamertag MagicGinjaninja
    • 07 Volvo V70 T5
« Reply #29 on: 02 July 2009, 00:27:50 »
other thing you can play with is covering the dome in the centre of the dash by the screen, see if that affects the fan speeds
what does that dome do? I've been wondering since I've had the car what it's for
07 Volvo V70 T5 SE ex police
Pages: 1 [2] 3  All   Go Up
