Author Topic: 2.2 Downpipe Removal  (Read 1032 times)
« on: 05 July 2009, 17:52:00 »
Just to double check, to remove the downpipe on the 2.2 omega, i can just remove these 2 bolts which hold the downpipe to the manifold?
I just sprayed them with WD40 @MDTM i know WD is not a penetrating oil but its the best i have.
I plan to pop these two bolts off, and again after the second cat before the exhaust, and remove that whole section.
Welung666
Re: 2.2 Downpipe Removal
« Reply #1 on: 05 July 2009, 18:44:00 »
There are 4 bolts on the manifold flange, you ca remove the rear 2 and just loosen the front 2 (the one closest to the block is a pain in the @rse to get at), then it's the 2 joining it to the middle section and a bolt just after the curve on the front of the floor pan. You'll need the front fairly hight to swing the pipe off the 2 loosened manifold bolts. I find it easier (as I don't raise the car by much) just to take all 4 off :P
« Reply #2 on: 05 July 2009, 18:46:25 »
4?
I could only feel 2  :-/
Welung666
« Reply #3 on: 05 July 2009, 18:50:56 »
4?
Look down from above the battery and you'll just about see the front 2, the rear 2 are on the back 2 corners of the downpipe flange. :y
« Reply #4 on: 05 July 2009, 18:53:31 »
4?
i'll pop off the heat shield and take a look  :y
Welung666
« Reply #5 on: 05 July 2009, 18:55:43 »
No need to take the heatshield off, the front 2 bolts are just above the engine mount mounted heat shield just inside the curve (block end) and near the other end. The awkward one I tend to use 1 13mm open ended spanner and slacken off until finger tight but careful you don't drop it LOL
« Reply #6 on: 05 July 2009, 18:56:52 »
Thanks  :y
Welung666
« Reply #7 on: 05 July 2009, 18:57:50 »
The amount of times I've had the cats off the gold 2.2 here I can take it off in my sleep ;D
« Reply #8 on: 05 July 2009, 19:02:25 »
Did you also remove the pre cat leccy connector?
Assume its best to disconnect on the connector rather than remove the sensor from the cat?
Welung666
« Reply #9 on: 05 July 2009, 19:17:02 »
Yea, because I was removing the whole cat section I just unplugged the 2 lambdas. Front one is behing the head, rear is plugged in near the selector switch on the gearbox.
Are you just opening the manifold joint to re-seal or taking the whole pipe off?
« Reply #10 on: 05 July 2009, 19:26:44 »
It needs to totally off, need a replacement flexi join put on.
Welung666
« Reply #11 on: 05 July 2009, 19:31:12 »
Thought you might be taking it off completely. Leave the centre support bolt till last as it'll hold the heaviest bit (I.E. the cats) in place until you're ready :y
« Reply #12 on: 05 July 2009, 21:06:45 »
Thanks for you help on this  :y
Page created in 0.033 seconds with 16 queries.
