Author Topic: Coolant loss. A word of caution. Could save you ££  (Read 1797 times)
Noknowledge
« on: 04 July 2009, 18:57:16 »
Hi all.
For some time now I have been slowly losing coolant on my Elite V6 3ltr. No rise in temp etc for a long time. I could find no leaks but the loss gradually increased so I began to suspect CH gasket. Took the car to a local garage who (Supposedly) did a compression and dye test and was told I needed new gaskets at a cost of around £1500.00 fitted!!!
Last week I drove 60 miles and got almost total loss and temp rise. Let it cool down and refilled and noticed a leak right at the back of engine. Popped it to a nearby garage run by an honest guy and got the prob fixed for £72.00!!!  It was a plastic valve with I think 4 hoses. The valve had gradually siezed up and finally closed. I think it may be inlet/outlet to heater matrix. I was in a hurry so didn,t really get to find out exactly what the valve does but it sits at top of engine at the rear near the bulkhead.
I thought I would post this in case anyone else gets the same problem/symptoms.
Cheers
Re: Coolant loss. A word of caution. Could save you ££
« Reply #1 on: 04 July 2009, 18:59:17 »
That was you Heater Bypass Valve (HBV)
3 coolant pipes, and a vaccum pipe
A very common fault, and often misdiagnosed  >:(
glad you are sorted  :y
Varche
  • middle of Andalucia
    • Golf Estate
« Reply #2 on: 04 July 2009, 19:15:53 »
Hi NoKnowledge
Welcome to the forum!
Won't be long before you can change your user name to "knowledge"! :) :)
Varche
RossMk2
  • Dudley, West Midlands
« Reply #3 on: 04 July 2009, 19:39:59 »
I also gradually loose coolant - can see it slightlight running down just under the heads making block look wet - and today did a compression test for other reasons and all was ok so i suspect i have this problem among others!
Does anone have a picture or guide or something where i can locate said HBV? Engine is in a different car and the other way around so picture would help i think
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
« Reply #4 on: 05 July 2009, 07:00:17 »
Have a read of this:-
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
I like red cars
RossMk2
« Reply #5 on: 05 July 2009, 14:58:26 »
Right.... i dont seem to have a HBV! looks like it has been binned pipework been created to mate up to the astra heater pipework.
« Reply #6 on: 05 July 2009, 21:27:37 »
You would have if you drove an Omega  :) :)
RossMk2
« Reply #7 on: 06 July 2009, 08:00:31 »
Yep i sure would! Just means the leak is coming from somewhere else, the story continues.
