Author Topic: fault code  (Read 1552 times)
bluehawk
fault code
« on: 05 July 2009, 09:04:56 »
have the following fault code and car in limp mode  any idea on solution
P0700   EOBD Error stored by Transmission Control (TC) Modul
Chris_H
  • E London/Essex UK
    • Jag XF Portfolio S 3.0D
Re: fault code
« Reply #1 on: 05 July 2009, 09:52:51 »
Well off my range of experience but it sounds as though the auto box (I presume you have one?) has a problem.  I also guess that a pukka Tech2 could read the actual problem from the auto box ecu.
From the Gunson list of codes:
P0700 Transmission Control System (MIL Request).  I know that doesn't add much but the auto box codes may well be Omega (or GM) specific.
Probably need to ask someone on here who has Tech2.
« Last Edit: 05 July 2009, 14:25:42 by ChrisH174 »
First Vauxhall - PABX Cresta; Previous, previous Vauxhall - 3.0 12v Senator CD; Previous Vauxhall Omega Elite 3.0V6 Saloon Auto
bluehawk
Re: fault code Help ?????????????
« Reply #2 on: 05 July 2009, 21:49:58 »
Any More suggestions
Re: fault code
« Reply #3 on: 06 July 2009, 06:07:24 »
you will need a good reader to ask the gearbox what is really wrong.
may be down to low fluid, but could be a host of other issues
Re: fault code
« Reply #4 on: 06 July 2009, 11:01:42 »
As said, you need a good code reader to ask the gearbox what's wrong - the engine fault code you have is just a code to say the gearbox ecu has asked the engine ecu to reduce power and to notify the driver that something ain't right
