Author Topic: Still Cutting Out  (Read 1542 times)
abertawe1970
  • shropshire
Still Cutting Out
« on: 02 July 2009, 13:39:10 »
Just had a new IACV and fitted it, but it still will cut out but not all the time. It's only when I’m at a junction at tick over at between 500 & 600 rpm, As from my other posts I’ve had the gearbox oil and filter changed, as well as the left side crank shaft sensor.
Am I missing anything stupid, has anyone else had this problem and how did get fixed?
Re: Still Cutting Out
« Reply #1 on: 02 July 2009, 13:40:37 »
your car details in your profile would help...
Any fault codes?
oil changes up to date?
air filter clean?
breathers and throttle body clean?
abertawe1970
  • shropshire
« Reply #2 on: 02 July 2009, 13:42:33 »
3.0l V6 elite 2000 vreg, it had a  service not long ago.
jonathanh
  • coventry
« Reply #3 on: 02 July 2009, 19:31:13 »
had this on a veccy b (4 pot) and it turned out to be the MAF.  best best is to try to get  a fault code with the paperclip test - go from there
« Last Edit: 02 July 2009, 19:31:37 by jonathanh »
parking near Birmingham airport for members with +250 posts.  PM for info
abertawe1970
  • shropshire
« Reply #4 on: 08 July 2009, 17:30:26 »
Found out the MAF sensor was upside down, the arrow on the pipe was facing down but the sensor arrow up. Would this make any difference?????
Dazzler
  • Haverhill, Suffolk
« Reply #5 on: 08 July 2009, 17:37:39 »
Try it, also has the fuel filter been changed??????
abertawe1970
  • shropshire
« Reply #6 on: 08 July 2009, 17:40:14 »
I have just turned it the right way up, it seemsw to run alot better. Thanks.  :)
