Author Topic: *$%*ing seat!  (Read 3022 times)
*$%*ing seat!
« on: 13 July 2009, 18:48:07 »
Any sensible suggestions?
I can see the offending 10p stuck right at the back of the seat runner. As you all know the seat's to go forward enough to get the rear seat bolts out ....... but there's 10p stuck & I can't get the b**** out! It's solid behind the seat belt anchor bolt bracket!  :'(
Re: *$%*ing seat!
« Reply #1 on: 13 July 2009, 19:04:55 »
Could have been worse at least it wasn't a pound coin ;)
Sorry mate couldn't resist.
Tried a longish drift and hammer?
Welung666
Re: *$%*ing seat!
« Reply #2 on: 13 July 2009, 19:22:23 »
Last time I had a coin wedged in the runner I used my b@stard bender (and very strong, thick 18" screwdriver) and the side of a claw hammer. A couple of sharp taps and ping! It nearly had my eye out ;D
i260
  • Newport, South Wales
Re: *$%*ing seat!
« Reply #3 on: 13 July 2009, 20:01:42 »
Huh! I thought you were having a go at the 'sporty' arm of VAG  ;D
Saab 9-5 Aero 260ps
nick v6
  • walsall / west midlands
Re: *$%*ing seat!
« Reply #4 on: 13 July 2009, 20:22:18 »
got the same problem with my passenger seat
and i cant get to it
Re: *$%*ing seat!
« Reply #5 on: 13 July 2009, 20:30:26 »
One of those 3-prong spring thingmies is what I used to get the 10p out of the seat rails in the old miggie .. has a plunger one end, you push it the 3 spring claws extend out and open, release the plunger they go back in... hopefully griping whatever you are trying to move ...  tok about an hour to get the 10p out .. but got there in the end ...
No idea what the thing is called .. :(
Mine cost 99p in the £1 shop .. :)   you can pay loads more if you want .. :)
http://www.jpgelectronics.com/products.asp?partno=Y057F
« Last Edit: 13 July 2009, 20:35:03 by entwood »
Re: *$%*ing seat!
« Reply #6 on: 13 July 2009, 20:46:57 »
The thing is ..... I can't now see the bugger, cos I hit it with a long screw driver & a knocking stick!  :-[
It's still there, just out of sight!  :(
LordShiplane
  • Enfield
Re: *$%*ing seat!
« Reply #7 on: 13 July 2009, 22:31:53 »
I have also got a similar problem cept mine is a pound coin !!  :-[. Its stuck fast and coz the seat is just that little bit too far back it gives me back ache on long journeys. it is sooooo annoying. Just cant reach the barsteward thing.
A person needs only three tools: WD-40, duct tape and a hammer. If it doesn't move and it should, use the WD-40. If it moves and it shouldn't, use the duct tape. If either doesn't work use the hammer
Re: *$%*ing seat!
« Reply #8 on: 13 July 2009, 22:46:38 »
Got the bugger!!!  :y :y :y
Re: *$%*ing seat!
« Reply #9 on: 13 July 2009, 22:48:02 »
What a mess!
are you doing a how2 for the maint guides  ;D ;D ;D
Re: *$%*ing seat!
« Reply #10 on: 13 July 2009, 22:51:44 »
What a mess!
It involved a 3' long screw driver & a large mallet!!!  ;D  ;D  :y  :y
Re: *$%*ing seat!
« Reply #11 on: 13 July 2009, 22:53:14 »
ouch .. even worse than my one was !!
Re: *$%*ing seat!
« Reply #12 on: 13 July 2009, 22:54:23 »
The pair of you are probably breaking some ancient law, mutilating a picture of the queen like that.
stint in the tower for the pair of you  ;D
Re: *$%*ing seat!
« Reply #13 on: 13 July 2009, 22:57:30 »
 ;D ;D ;D ;D ;D
I'm consoling myself with the fact I'm not the only sad b'stard to take a picture of the offending mutilated coin!  ;D  ;D  ;D  ;D
Re: *$%*ing seat!
« Reply #14 on: 13 July 2009, 22:59:46 »
 ;D ;D ;D ;D ;D
If memory serves ... I was asked to put a piccie up when I also asked for help .... about 2 years ago !!!  :)  Good job imageshack doesn't time delete stuff ..  :)
