Author Topic: Code 19  (Read 1725 times)
gsizoli
  • Hungary
Code 19
« on: 14 July 2009, 06:56:42 »
Hi!
My car didn't start 1 year ago, so I replaced the crank sensor (to a geniue one).The cables were aranged correctly, it was checked. Now I tried the paperclip test and I've got code 19. The car starts fine and runs fine.So why I've got code 19?Is it mean any problem?It sounds strange if it could be crank sensor again....I dont want to repalce in evry year.Is the code needed to erase from ECU, or cancelled automaticallay?
Br
Zoli
Re: Code 19
« Reply #1 on: 14 July 2009, 07:09:07 »
the code should auto delete.
I am having a similar issue with a 14 month old sensor, check out my crank sensor longevity thread  :y
gsizoli
  • Hungary
Re: Code 19
« Reply #2 on: 14 July 2009, 07:24:23 »
OOpss.
My English is not the best what do you mean under the second sentence?
Re: Code 19
« Reply #3 on: 14 July 2009, 07:38:58 »
I had a similar situation where I had a code 19... It appears mine was just a rare situation where it didn't automatically clear itself :o :o :( :(
Re: Code 19
« Reply #4 on: 14 July 2009, 08:32:45 »
Clear the code 19 with code reader/tech2 and then see if it comes back  ;)
Re: Code 19
« Reply #5 on: 14 July 2009, 09:02:08 »
OOpss.
Sorry, I am havin a similar problem...
http://www.omegaowners.com/forum/YaBB.pl?num=1247427967/all
gsizoli
  • Hungary
Re: Code 19
« Reply #6 on: 14 July 2009, 10:23:08 »
OK, I will ask somebody to clean it, because I can't believe it if it fails so fast..
