Author Topic: oh sh*t !! alarm / locks  (Read 1637 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 14 July 2009, 10:54:13 »
HELP  :'( :'(
just went out to my car.
tried to unlock it with the remote, no responce  :-/
put the key in the lock and opened it that way alarm goes off so i shut the door and locked it with the key thinking the alarm would reset its self  :y
siren shuts down after ? minuites then indicators stop after ? minuites.
NOW just tried to open car with remote and key and both won't move the locks  >:( >:(
iv'e only got one remote and one key  :'(
idea's quick please  :y :y
got to use the car ............ eh now  :'(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: oh sh*t !! alarm / locks
« Reply #1 on: 14 July 2009, 11:02:19 »
just put the key in the lock and twisted HARD !!
felt a click but door lock buttons are still down but door is now open !
car starts but door lock buttons won't move up !!
alarm led is still flashing but no indicators or siren
« Reply #2 on: 14 July 2009, 11:06:56 »
Battery failing in remote fob :question
Fuse #20 under steering column :question
« Last Edit: 14 July 2009, 11:10:25 by RobG »
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 14 July 2009, 11:11:46 »
could be mate  :y
trouble is i've just found a spare remote of a old mig  :y
can it be programed to this car with the alarm red led flashing ?
would i be better off just disconecting the battery for a bit and maybe the thing will reset somehow ?
all doors are deadlocked at the moment  :'(
« Reply #4 on: 14 July 2009, 11:14:59 »
could be mate  :y
Not sure but I don`t think so.Does the car`s remote have an LED on it :question
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 14 July 2009, 11:26:58 »
yeh, led's working on the remote  :y
fuses seem ok  :y
and just to confuse you even more ............ last night, the sunroof was tilted when it started to rain.
rather then going outside, i unlocked the car using the remote ( from the doorstep ) and then locked it using the remote ( keeping my finger on the lock button ) to shut the sunroof ........... it shut no problem :y
NOW and here is the good bit .............. just sat in the car with the ignition on and opened the sunroof  :y
great, that works but as soon as i take the key out of the ignition the sunroof shuts on its own !!
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #6 on: 14 July 2009, 12:51:31 »
" bump"
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 14 July 2009, 13:03:42 »
just had the battery disconected for 30 mins then reconected it .
alarm went off ............ wouldn't shut down with remote  :'(
gallon of unleaded and a match ? >:(
Welung666
« Reply #8 on: 14 July 2009, 13:20:51 »
Just switch the ignition to number 2, that should stop the alarm. Then try a new battery and re-sync the remote (ign to number 2 and press the lock button, doors should lock and unlock). :y
« Reply #9 on: 14 July 2009, 13:38:12 »
Yep, unlock the car and turn the ignition to the position II, press and hold the remote button.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #10 on: 14 July 2009, 13:51:11 »
done that  :y :y
it took 5 goes for the drivers door button to pop up but it seams to be ok now  :y
thanks to rob / lee / mark for your help   :y
i can put that unleaded in the tank now  ;D ;D
Page created in 0.048 seconds with 16 queries.
