Author Topic: Retro fitting cruise control  (Read 1228 times)
megaOmega
« on: 15 July 2009, 13:09:02 »
Hi, as i am hell bent on getting a 2.0 omega not a v6 after looking at an engine bay on the internet and the fact that you need "Double Jointed Fingers" to change the cam belt.
I have heared that you can fit Cruise control, can you do this on the 2.0, i doubt the one i will be getting will have fly by wire so is it still possible?
If i fing the stalk can i just plug it into the ECU without a ECU upgrade?
any help please.... ::)
Re: Retro fitting cruise control
« Reply #1 on: 15 July 2009, 13:11:23 »
the 2.0 can support cruise (normally) 1 or 2 havent had the loom.
you need a stalk, actuator motor (with cable long enough for a 2.0, quite rare), and pedal switches
v6's aint that bad to work on with a little practise.
megaOmega
« Reply #2 on: 15 July 2009, 13:15:58 »
So... are all 2.0's NOT fly by wire
i just like the idea of a plug and play mod.
« Reply #3 on: 15 July 2009, 13:18:59 »
2.2's are drive by wire, 2.0's are not
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
« Reply #4 on: 15 July 2009, 13:21:27 »
Get a Traktor - Cruise is plug 'n play  :-*
« Reply #5 on: 15 July 2009, 13:21:27 »
even with the cable operated models, its just another unit to plug in  :-/
the pedal switches are more awkward!
Page created in 0.05 seconds with 16 queries.
