Author Topic: Engine will not start !!!!  (Read 3625 times)
Richard A
  • Aldridge, West Midlands
« on: 15 July 2009, 16:40:42 »
Battery wizzing the engine over, all the dash lights are on but will not fire-up, checked lots of connectors still no go  :( :(
Any help.
regards
Richard A
richard a
Ziad
  • Bahrain
Re: Engine will not start !!!!
« Reply #1 on: 15 July 2009, 16:56:33 »
Hey Richard,
I suppose you already had a go at the spark plugs and HT leads? Is the engine cranking properly?
Richard A
« Reply #2 on: 15 July 2009, 17:17:22 »
Yes all seems normal !!!!!!
Thanks for the reply
regards
richard a
richard a
KillerWatt
« Reply #3 on: 15 July 2009, 17:39:02 »
Pull a plug....
Are you getting a spark?
Is the plug wet?
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
« Reply #4 on: 15 July 2009, 17:46:24 »
What engine do you have? what year car? and have you had any work done to the car recentlly. We need a few more details from you to be able to be more helpful mate.
« Last Edit: 15 July 2009, 17:47:55 by ffcgary1 »
Jaguar XJ6
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 15 July 2009, 17:53:23 »
Do you have any codes?
Richard A
« Reply #6 on: 15 July 2009, 18:58:18 »
Sorry I did have the details on the site going back in time, anyway 1998 2.5 petrol Elite auto saloon, 158000 miles.
Checked for codes, apart from 12 & 31 the main problem is 73 - Mass Air Flow Sensor Voltage Low, what next - clean it, replace it, shake it, shout at it  :-/ :-/
regards
richard a
richard a
Ziad
  • Bahrain
« Reply #7 on: 15 July 2009, 19:05:28 »
Hey again Richard.
I  suggest that before you go about changing parts, you have a look at the fuses both under the bonnet as well as under the steering wheel. Check if you getting a spark when you pull out a plug, check if any plugs are wet. and yes, not to forget check if the engine is getting fuel.
HTH
Ziad
Richard A
« Reply #8 on: 15 July 2009, 19:23:35 »
Maybe worth saying at this point that this has happened 4 times since I replaced the radiator in May, the difference is in the past the car has started after being left for an hour. Plus since then the car has covered 2,500 mile and not missed a beat.
Help what have I done ?
regards
richard a
richard a
SP_3.2
  • Leicester
    • drives A6 allroad 3.0tdi
« Reply #9 on: 15 July 2009, 20:55:55 »
Just a long shot but could it be a crank sersor on the way out.
deviator
  • Chesterfield
« Reply #10 on: 15 July 2009, 21:17:44 »
Immobiliser? But I thought this brought up a flashing light.
FCR and cam lock off kit available. Deposit maybe required. Contact me.
ffcgary1
  • Mitcham,Surrey.
« Reply #11 on: 15 July 2009, 21:23:27 »
Hi richard hence my question earlier,  have you had any work done recently to your car , although they are not related we do need as much info as poss to help you.Still we move forward now, and your post stating that it started after an hour suggestes to me that sp3.2 is on the correct tack here with regard to the crank sensor starting to break down. Start with getting this changed as soon as poss or it will fail compleatly just when you dont need it to. God luck and post up your results. Gary. :y
Jaguar XJ6
Richard A
« Reply #12 on: 15 July 2009, 21:58:07 »
Update !!!!
Checked & cleaned MAF, also connections.
Removed 1 & 3 plugs, both dry, no fuel (or oil), disconnected  both feed and return fuel lines while turning over engine - no fuel. Replaced no 18 fuse, pump still no ticking, away to see if there is a relay.
Any thoughts, please.
regards
richard a
richard a
MutantCav
  • Gainsborough
« Reply #13 on: 15 July 2009, 22:12:21 »
My thoughts would whole heartedly be with the crank sensor...as said immbiliser would flash the eml...code 73 and/or 74 are common red herring codes when the crank sensor goes :y
« Last Edit: 15 July 2009, 22:13:15 by ShieldOfSteel »
ffcgary1
  • Mitcham,Surrey.
« Reply #14 on: 15 July 2009, 22:33:23 »
If the crank sensor is bad it will stop fuel going to the cylinders to protect the cats from being contaminated with unburnt fuel SO crank sensor first stop.
Jaguar XJ6
Page created in 0.018 seconds with 15 queries.
