Pages: [1] 2 3  All   Go Down
Author Topic: Rough as guts  (Read 8623 times)
Dubious
  • Nearer Swindon than Brisbane
Rough as guts
« on: 18 June 2009, 12:09:34 »
2000 facelift 2.5 CDX manual estate. Recent 'all makes' major service at VX dealer. 72k miles. Not used much recently. Not had the cambelt done yet.
Suddenly running really rough - vibrating, using a lot of petrol (25mpg at steady 60 in 5th according to the computer). Wasn't sure I was going to get home.
I don't have the cash to stump up at a garage and ask them to fix it, and if there's something badly wrong it's possibly going to cost more to fix than the car's worth.
Where do I start ? (I maintain my old VW camper but this is a different kettle of fish).
Thanks for your help.
Omega man 2
Re: Rough as guts
« Reply #1 on: 18 June 2009, 12:31:11 »
Missfire?
Try the paperclip test :y
Omega man 2
Re: Rough as guts
« Reply #2 on: 18 June 2009, 12:38:58 »
Expect a code 19 ;D
Dubious
Re: Rough as guts
« Reply #3 on: 18 June 2009, 13:05:51 »
Aha ! The paperclip test.
To add to my woes, this happened on the way back from the dentist after a filling. Do I wait until the anaesthetic wears off, or do it now ?
MutantCav
  • Gainsborough
Re: Rough as guts
« Reply #4 on: 18 June 2009, 13:11:52 »
Do it now...just shove one end of paperclip in pin 4 and other end in pin 6...
Dubious
Re: Rough as guts
« Reply #5 on: 18 June 2009, 13:24:42 »
I'm so disappointed - I'm getting 31 (no revs) with the engine off and just 21 with the engine running.
Re: Rough as guts
« Reply #6 on: 18 June 2009, 13:28:17 »
21   Throttle Position Sensor (TPS) Voltage High
not sure what you do next though....
Dubious
Re: Rough as guts
« Reply #7 on: 18 June 2009, 13:33:23 »
Sorry - that was meant to be 12 (start of diagnostics)
Re: Rough as guts
« Reply #8 on: 18 June 2009, 13:34:31 »
in that case, hmmmm
try pulling a plug lead or 2 and checking for oil in the plug wells.
Re: Rough as guts
« Reply #9 on: 18 June 2009, 13:45:23 »
Suspect HT at best, or at worse (if the inteval has been ignored) cam timing
Dubious
Re: Rough as guts
« Reply #10 on: 18 June 2009, 14:10:37 »
in that case, hmmmm
I could only reach the front left, and that was clean.
Dubious
Re: Rough as guts
« Reply #11 on: 18 June 2009, 14:19:25 »
Maybe it is time to get the cambelt done
Dubious
Re: Rough as guts
« Reply #12 on: 18 June 2009, 15:29:26 »
..or maybe not. My trusty Snap-On timing light is getting a reading from the middle HT lead on the left (one day I'll know what the cylinder numbers are), but not the front one on that side.
I can't physically get to enough of any of the others to try them, and can't even trace them to wherever they come from.
Maybe time to get a manual ?
Re: Rough as guts
« Reply #13 on: 18 June 2009, 15:35:36 »
The DIS pack lives at the back of the nearside bank of cylinders ie 2, 4 & 6 It's pain in the harris to get out. You need the plastic scuttle panel off from under the screen.
No 1 cylinder is front driver's side  :y
Dubious
Re: Rough as guts
« Reply #14 on: 18 June 2009, 15:38:03 »
Thanks. I don't want to get it out - I'd like to be able to get the Snap-On clamp round each of the leads with the engine running. Does that sound possible ?
Pages: [1] 2 3  All   Go Up
