Author Topic: mayo in header tank  (Read 1144 times)
paul36uk1
  • midlands
mayo in header tank
« on: 07 August 2009, 11:51:33 »
hi all.i have a 2001 2.6 mv6,i havent used it for a couple of months,just took it out for 20mins or so then looked to see if the water level was ok,noticed a lot of mayo ( cream)in the tank,it it head caskets?
cheers
Re: mayo in header tank
« Reply #1 on: 07 August 2009, 11:55:12 »
sounds more like oil cooler  :y
paul36uk1
  • midlands
« Reply #2 on: 07 August 2009, 11:57:41 »
thanks jimbob,ive read about some folks having heater probs with mayo but my heater seems to be ok
Welung666
« Reply #3 on: 07 August 2009, 12:07:40 »
It won't be if you keep using it, get it sorted before you use it again :y
paul36uk1
  • midlands
« Reply #4 on: 07 August 2009, 12:09:38 »
would it help to drain the system down?
« Reply #5 on: 07 August 2009, 12:20:56 »
You need to drain the system to replace the cooler and flush it through. As above, don't use it again until you get it fixed :y :y :y
