Author Topic: MV6 engine change  (Read 803 times)
MV6 engine change
« on: 12 August 2009, 17:05:03 »
I now have the engine for the MV6, all I need is time, and I can swap it over
Just to recap - the "new" engine, although v low miles, is from an older Omega
I think for now, I'm going to keep it all original and use the auto box. The new engine is from a manual.
So just to confirm, the process will be
- remove knackered engine.
- fit ancils such as DIS pack, all sensors, loom, from old engine to new
remove flywheel and clutch and fit flex plate to new engine
Mate up engine and autobox out of the car
Lift in the new unit
I'm pretty sure I will be fine, but any pointers from anyone who's done an Omega engine change before would be much welcome
Re: MV6 engine change
« Reply #1 on: 12 August 2009, 20:44:03 »
Near enough....you can leave the thrust bearing in the end of the crank
