Author Topic: oh flipping heck !!!! ( polite version )  (Read 3071 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 12 August 2009, 14:55:29 »
good afternoon and welcome too another of my nightmares  >:( >:(
got myself a bargen stereo of flea bay last week and yesterday i decided to fit it  :'(
bit of a tight fit it was so i gave it a good shove and in it went  :y
10 minuites later i get the low coolent warning on the dash and on looking i found half the water was gone  :'(
got it home and waited for the car to cool down abit then topped it back up  :y
pulled the stereo out and checked if i could see and water ............ nowt  :'(
checked the footwells .............. nowt  :'(
heaters / cooling seems too work ok  :y
its now pumping out about a pint of water in 10 minuites driving and i can't see any puddles  :'(
any idea please  :y
Ghost
  • Seaham, North East england
    • 2.6 V6 CDX Estate
Re: oh flipping heck !!!! ( polite version )
« Reply #1 on: 12 August 2009, 14:58:28 »
is your Hbv ok? can you see any leaks anywhere?
He who brakes Looses
To old to die young
« Reply #2 on: 12 August 2009, 14:59:09 »
hmmm where its gone is stange, but loss 'could' be an air lock.
let the car run (stationary) with heaters on hi, no header cap on the tank
squeeze any pipes you can see, that should sort any air lock.
once its cooled, you can top up to correct level and monitor for any loss.
presume no oil in water?  and no mayo gunk on dispstick?
is your hbv dry?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #3 on: 12 August 2009, 15:00:37 »
is that the tinker underneath the windscreen scutle left side ?
no leaks on the floor so im just gonna jack it up and look
Ghost
    • 2.6 V6 CDX Estate
« Reply #4 on: 12 August 2009, 15:04:12 »
Yep thats the one :y
To old to die young
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 12 August 2009, 15:04:27 »
is your hbv dry?
oil mayo free  :y
flushed the system 6 weeks back and has run great since ( after i got all the air out )  :y
doing my head in that it happened 10 mins after i pushed the stereo in  :'(
Ghost
    • 2.6 V6 CDX Estate
« Reply #6 on: 12 August 2009, 15:07:44 »
Jimbob could be right it might just have been an air lock, if theres no leeks to see follow what jimbob said and keep your eye on it :y
To old to die young
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #7 on: 12 August 2009, 15:11:14 »
gonna jack the front end up now and have a look underneath now with it running  :y
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #8 on: 12 August 2009, 15:42:04 »
HBV ???
don't suppose its a round looking device with 2 water pipes at the bottom and what looks like a vacume pipe going into the top is it  :'(
at the back of the engine next to the breather bits and coil pack ?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #9 on: 12 August 2009, 15:49:44 »
now got water on the floor at the back of the engine  :'(
Ghost
    • 2.6 V6 CDX Estate
« Reply #10 on: 12 August 2009, 16:10:13 »
Yep HBV is fuba you need to change it £35 from vx I believe.
To old to die young
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #11 on: 12 August 2009, 16:29:19 »
just pulled one off my saloon im breaking mate  :y
just lost my business and not getting dole so well skint at the moment  :'(
hopefully it will be ok if i flush it out  :-/
any tips on changing the tinker  :y
« Reply #12 on: 12 August 2009, 17:04:31 »
there is a guide (see my sig)
basically wipers and scuttle off, then you have enough room to get something in to release the clips and slide the pipes off.
you will get scratched to hell!
some remove plenum, but not needed.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #13 on: 12 August 2009, 17:40:58 »
cheers for the advise lads.
engines too hot at the mo so i'll get my arse out of bed in morning and do it when its cool  :y
may aswel do the breathers at the same time  :y
i'll keep you posted  :y
Ghost
    • 2.6 V6 CDX Estate
« Reply #14 on: 12 August 2009, 18:03:48 »
Have fun and dont get up to early Lol. :y
To old to die young
Page created in 0.216 seconds with 16 queries.
