Author Topic: Dis pack on v6  (Read 1770 times)
samrey4u
  • norwich
  • Big stranglers fan
    • 2003 2.2 cd saloon
Dis pack on v6
« on: 25 August 2009, 13:09:10 »
Hi i need to know where the corresponding ht leads connect to on the dis pack.
5 3 1
2 6 4
front of car
is this correct or can anyone give a more detailed description. cheers
« Last Edit: 25 August 2009, 13:29:35 by samrey4u »
sam
Bumbazor
  • Worksop
Re: Dis pack on v6
« Reply #1 on: 25 August 2009, 13:15:00 »
I think it goes 2 6 4 on the bottom but there's a guide somewhere that says for sure. Also it should be marked on the dis pack.
goonv6
Re: Dis pack on v6
« Reply #2 on: 25 August 2009, 14:25:56 »
If you look on the rocker cover, it'll tell you the order, just correspond the cylinders to the numbers on the pack.
Re: Dis pack on v6
« Reply #3 on: 25 August 2009, 19:53:59 »
You assume the DIS is off the car. I expect Samrey4u has till got his DIS fitted & wants to avoid removing it!  ;)  ;)  ;)
I can tell you when I get home from work ..... at 10:45  ;)
Toby
  • Ringwood, Hampshire
Re: Dis pack on v6
« Reply #4 on: 25 August 2009, 20:18:47 »
Having just pulled mine out I can tell you.
Assuming it is mounted horizontally you are correct samrey4u with you original post.
        Bulkhead
DIS    5   3   1
Plug   2   6   4
      Front of car
samrey4u
  • norwich
Re: Dis pack on v6
« Reply #5 on: 25 August 2009, 20:30:55 »
All sorted now many thanks for your replies , and yes dis was still on the car  :y trouble i had ,was the plonker who had car before me , decided to replace number 6 plug lead with one that said 4 , hence i had 2 x number 4 leads lol. pulled all plugs of dispack and got mixed up when replaced with new leads but its all running now  :y
sam
