Author Topic: Ebay Chips  (Read 1517 times)
mininax
Ebay Chips
« on: 04 December 2007, 12:49:12 »
Has any one bought one of the 5 pound ebay chips
My mate bought one and it was a little resistor to short out the air flow meter?
 :D bout 30p's worth! surly a paper clip is cheeper!!
Would this actually be a gain to the car?
Re: Ebay Chips
« Reply #1 on: 04 December 2007, 12:52:29 »
Beleive they make the car run better for a couple of miles, then the ecu relearns and gain is gone.
Think at this point they can even have negative impact :(
« Last Edit: 04 December 2007, 12:52:48 by jimbob »
Re: Ebay Chips
« Reply #2 on: 04 December 2007, 12:59:05 »
They make the ECU "think" the air coming in is colder.. this implies a higher mass of air, so requires more fuel ... thus the ECU gives a bit extra fuel than needed so giving slightly more power.. and worse fuel economy as the car now runs rich all the time
The chips sold to improve economy work in the other direction, fooling the ECU to run lean all the time ...
Neither do the engine any good long term
Markie
  • Lanarkshire, Scotland
    • RS4, BMW X5, Range Rover
Re: Ebay Chips
« Reply #3 on: 04 December 2007, 13:03:26 »
Chips from ebay...wont they be cold by the time you get them... :D
Seriously i would doubt the power gain claims made by them
raximax
  • dundee
Re: Ebay Chips
« Reply #4 on: 04 December 2007, 13:27:56 »
do not chance it .my friend bought one for his msd veccy but never fitted it as hs friend fitted one to his car then blew his engine :o :o
mmeeggaa
Re: Ebay Chips
« Reply #5 on: 04 December 2007, 13:28:44 »
Total rubbish... Even at 5 quid they're a rip off. The resistor inside is a couple of pence! >:(
From the "an engine is a bonfire" school of tuning. (Pour more fuel in and it's bound to generate more power).
Bo Bo
  • Coventry
Re: Ebay Chips
« Reply #6 on: 04 December 2007, 14:40:02 »
I tried one a few years ago & the EML came on after a couple of seconds, took it straight back off...
Re: Ebay Chips
« Reply #7 on: 04 December 2007, 14:43:12 »
They would have more effect on the coolant sensor...........still a BAD idea though.
Note that the effect of buggering with air temp sensing has a VERY small imapct (this sensor was actualy removed on the later 2.6/3.2 V6 power plants)
Markjay
  • London
Re: Ebay Chips
« Reply #8 on: 04 December 2007, 22:58:17 »
If it's going to the MAF... it will full the ECU into thinking more air is coming in... so you will get more fuel... and a very rich mixture... I wonder what the cats will think about this?
Alas, no more Omegas....
Re: Ebay Chips
« Reply #9 on: 04 December 2007, 23:02:37 »
as the maff effectivity measures temp (indirectly) anyway.
agree, should go on cts for best effect, but ultimately pointless.
Re: Ebay Chips
« Reply #10 on: 04 December 2007, 23:15:55 »
The mixture goes quite rich at full throttle anyway, and they just temporarily stop working as effectively. During cruise, the closed loop control will bring the mixture back under control, so the "chip" won't affect mixture, unless it takes the fuel out of the adjustment limits allowed, in which case you'll get an EML.
The ECU might give you a little more ignition advance if it's fooled into thinking the air's colder, but as has been said, it'll be a minimal adjustment.
At the end of the day, VX have spent a lot of hours setting up the engine management, so the likelihood of improving it in this way is slim. Granted, there are probably some compromises in the factory setup to get the emissions right, and to guarantee that it doesn't grenade under the most arduous conditions, but the only way to get an improvement, and a small one at that, is a properly developed chip.
Page created in 0.027 seconds with 16 queries.
