Author Topic: projector lights  (Read 1797 times)
autov6
  • swadlincote
projector lights
« on: 09 September 2009, 18:26:11 »
how do you get the side light bulb out does it just twist 90 degress or does it screw al the way out thanks for your help much appreciated
« Last Edit: 09 September 2009, 18:27:34 by autov6 »
Re: projector lights
« Reply #1 on: 09 September 2009, 18:28:22 »
IIRC should be a push fit
MutantCav
  • Gainsborough
« Reply #2 on: 09 September 2009, 18:32:36 »
Twists and pulls out
autov6
  • swadlincote
« Reply #3 on: 09 September 2009, 18:46:16 »
thanks mutantcav for bringing them down top man did you take a walk round ikea ,
how much do they twist not alot of room to get ya hand in
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #4 on: 09 September 2009, 19:04:43 »
On mine I just turn them side to side and pull at the same time. To refit it is just a push.
Al
If it aint broken, you aint trying hard enough
MutantCav
  • Gainsborough
« Reply #5 on: 09 September 2009, 19:25:15 »
No problem mate, yeah had a nosey around IKEA and ended up buying a rug for the front room :y
As you are replacing the lights...just undo the 3 bolts to remove light (after removing centre grille and the under light lip things) and then fiddle about removing the plugs in the lights when its loose...much easier :y
But doesnt need much of a twist as said twist and pull and there you go if you want to undo it first
« Last Edit: 09 September 2009, 19:29:23 by ShieldOfSteel »
autov6
  • swadlincote
« Reply #6 on: 09 September 2009, 20:54:53 »
how do you remove the under light thingy and the washer jets
al brown
  • alton, hants
« Reply #7 on: 09 September 2009, 21:01:55 »
Facelift or not
Al
Welung666
« Reply #8 on: 09 September 2009, 21:07:35 »
It'll be a pre or mini facelift. Jets just pull off, grasp them firmly, pull it out to full extent and a quick sharp tug will see it off. The strips under the headlight are on 'snap' clips (I call them snap clips because they do if you're not very gentle with them!), I can remove the headlights without removing the strips. I reach through from where the grill was to the bolts. :y
al brown
  • alton, hants
« Reply #9 on: 09 September 2009, 21:11:50 »
On a pre the washer are held on by a little clip which will be visalble when you pull the jet out. Dont break it or you will lose your jets next time you use them. The bits under the lights are3 held on by the clips and a screw behind the grill.
Al
autov6
  • swadlincote
« Reply #10 on: 09 September 2009, 22:03:56 »
cheers lads i`ll try 2mora wen theres a bit more light  :y
