Author Topic: VENTILATION STOPS 2.5 CD  (Read 4158 times)
dbr
  • north east.
    • 1997. 2.5CD petrol
« on: 01 September 2009, 19:42:08 »
WHEN GOING UPHILL WITH THE ENGINE UNDER LOAD THE AIR STOPS COMING OUT OF THE VENTS. IT IS EASY TO RESRTART....JUST LIFT OFF THE ACCELERATOR FOR A MOMENT. YOU CAN HEAR A WHISTLE WHEN THE AIR STOPS.
A VACUUM PROBLEM OF SOME SORT. ANY IDEAS?
Re: VENTILATION STOPS 2.5 CD
« Reply #1 on: 01 September 2009, 19:46:50 »
You are on the right lines, sounds like you have vac problems.
Check that vac system correctly wired (Marks DTM Calib posted a 'map' of vac connections in Maintenence Guides section :y)
dbr
  • north east.
« Reply #2 on: 01 September 2009, 20:16:10 »
with technology, i'm a bit of a luddite. looked where you suggested but did not find it. only saw previous 25 posts
dbr
  • north east.
« Reply #4 on: 01 September 2009, 20:56:54 »
thanks will check lines
« Reply #5 on: 01 September 2009, 21:00:29 »
where are you based? Consider adding location to profile, someone may be willing to help?
dbr
  • north east.
« Reply #6 on: 01 September 2009, 21:11:53 »
newcastle upon tyne
« Reply #7 on: 01 September 2009, 21:42:34 »
newcastle upon tyne
Ah, soz, too far for me to assist ;D
dbr
  • north east.
« Reply #8 on: 02 September 2009, 18:30:41 »
all tubes are attached and look as if they are in the correct place. is it possible something is sticking or not opening fully?
« Reply #9 on: 02 September 2009, 19:35:45 »
Its possible that the one way valve in the vac tank on the pollen filter housing is goosed......you can fit one for an aquarium in series to sort.
Do check for chafed vac pipes though
dbr
  • north east.
« Reply #10 on: 03 September 2009, 16:55:38 »
WILL LOOK
dbr
  • north east.
« Reply #11 on: 12 September 2009, 19:51:50 »
found a leak on a vacuum pipe. Are repair kits available or is it a new pipe?
al brown
  • alton, hants
    • Rusty 97 3l estate
« Reply #12 on: 12 September 2009, 20:07:56 »
Ask anyone breaking  a mig in the parts section.
Cheapest option by far.
SAFC Fan Al
If it aint broken, you aint trying hard enough
Kaycee
  • Doncaster
« Reply #13 on: 13 September 2009, 07:49:41 »
as a temp repair cut the pipe were leaking and insert a bit of brake pipe to join back up motor factors will give you a peice for pence i made temp repair on my last cdx meant to change pipe 4 years on was still ok
There is a tide in the affairs of man if taken at the flood will lead on to greater things
dbr
  • north east.
« Reply #14 on: 13 September 2009, 13:44:03 »
thanks
been to scrapyard and  got pieces that hopefully will cure the problem
