Author Topic: car cuts out when aproaching a junction  (Read 2990 times)
stevie 123
« on: 16 September 2009, 11:11:45 »
please help its doing my head in i have a vauxhall omega elite 1999 t 3.0 v6 some times when aproaching a junction the car just dies it starts on about the 3 turn of the key then drives fine again there is no ecu light comming on please if u have any ideas could u let me no ive change the idle control valve and it still happens
« Last Edit: 16 September 2009, 11:43:35 by torresman »
Re: car cuts out when aproaching a junction
« Reply #1 on: 16 September 2009, 11:13:50 »
have you read fault codes?  if not do it and post em up (link in my sig)
will give us more to go on.
Is the car well serviced?  Air and fuel filters in good condition?
ohhh, and welcome to the forum  :y
« Last Edit: 16 September 2009, 11:14:08 by jimbob »
stevie 123
« Reply #2 on: 16 September 2009, 11:24:55 »
yes thanks it was serviced in april fuel filter changed and air filter there are not fault codes comming up as the ecu light is not comming on
« Reply #3 on: 16 September 2009, 11:26:25 »
makes no difference....many fault codes do not illuminate the light.
check for codes.
there are some that WILL cause breakdown, which dont illuminate the light.
stevie 123
« Reply #4 on: 16 September 2009, 11:28:25 »
how do i do it can u use a paper clip if yes where
« Reply #5 on: 16 September 2009, 11:29:48 »
http://www.omegaowners.com/forum/YaBB.pl?num=1189022687
yes, paperclip (depending what your car is....you havent said)
year / engine size will also help  :y
« Last Edit: 16 September 2009, 11:30:12 by jimbob »
stevie 123
« Reply #6 on: 16 September 2009, 11:38:17 »
1999 t elite 3.0 v6
« Reply #7 on: 16 September 2009, 11:57:54 »
that is paperclippable as per the above guide then.
Let us know the codes, and we can take it from there...
stevie 123
« Reply #8 on: 16 September 2009, 12:58:11 »
yes ok ill place them tonight many thanks
jonnycool
  • Merthyr Tydfil, S. Wales
  • We shag 'em, you eat 'em
« Reply #9 on: 16 September 2009, 15:35:38 »
It's probably something to do with the crank sensor (root of all evil) ;)
stevie 123
« Reply #10 on: 16 September 2009, 16:10:37 »
it was replaced in 2008 by vx,
stevie 123
« Reply #11 on: 16 September 2009, 17:36:20 »
done a fault code reading and nothing displaying no fault onli 1-2
« Reply #12 on: 16 September 2009, 17:50:57 »
No codes then....
can you check for air leaks....
1 way is spray carb cleaner round different bits of the engine....if there is an air leak the noise will change as it burns off the flamable cleaner
Pete Elite
  • Uxbridge, Middlesex
« Reply #13 on: 16 September 2009, 18:07:37 »
Hi Stevie and welcome to the forum :y.
  I had the same symptoms and after cleaning the breathers and ICV it was fine and problem not returned :y.
  Have you made sure that the ICV is pushed all the way home into the plenum, i tapped mine in gently with a piece of wood and a mallet to get a good airtight fit :).
  What are the idling revs, does it only do it when the car has warmed up?
stevie 123
« Reply #14 on: 16 September 2009, 19:55:58 »
hi yes it does it only when warm its idling about 600 -700 its getting right on my nerves at the mo the only thing i have noticed is that the seal is a very loose fit and the icv moves about
« Last Edit: 16 September 2009, 20:47:25 by torresman »
