Author Topic: Crankshaft bearing noisy  (Read 3741 times)
Radar
  • Berkshire
    • Elite 2.5 Auto
« on: 21 September 2009, 21:02:11 »
My crankshaft bearing makes a sqeaky sound and I wondered is it easy to lubricate without dismantling? It starts to make the noise after the engine has been running for 20 minutes plus.
I presume it is the crankshaft bearing (It sits at about 5 o'clock to the alternator.
Any help/ideas would be appreciated!
Re: Crankshaft bearing noisy
« Reply #1 on: 21 September 2009, 21:44:17 »
The crank shaft is the big one right at the bottom. It has quiet a few bearings, but not one that will squeak. If one does ... you've got real problems!  ;)  ;)  ;)
Try running your car without the 'fan belt' - not too long though cos your water pump is driven by it - and see if it makes any difference to your squeak and go from there.  :y
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
« Reply #2 on: 21 September 2009, 21:52:59 »
could be u need a oil change, filter cloged, check dip stick for a white or yellow colour, and allso check it viscosity ( how it moves in your fingers) if rough change the oil and filter, other thing that sounds like the crank making a sound it the timing belt retainer, usually start making a noise when they start getting hot.
Omega's is a life not just a car. also do ecu codes read and wiped or rest.., fix LCD tv & DVD recorders PS3's and most electrical equipment just e-mail me.
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #3 on: 21 September 2009, 21:58:37 »
Thanks for comments.
The noise is coming from the crankshaft area but i can't be 100% sure it is the cuprit. Oil and filter change done 3 weeks ago.
Cambelt, tensioners and water pump was changed in dec. 2007 - 17,000 miles done since then. Car at 87,000 miles now.
If it is the timing belt retainer is it easy to fix?
rustym95
« Reply #4 on: 21 September 2009, 22:06:04 »
as long as u lock the engine top and bottom about 5mins, the are just bearings, have to keep the timing locked in its marking. :y :y p.s would do the timimng belt if not been done yet save u any more problems coming up later as it will be locked into place. :y
« Last Edit: 21 September 2009, 22:08:33 by Russell_Hill »
« Reply #5 on: 21 September 2009, 22:12:01 »
If it's the 'fan belt'/auxillary belt, there's no timing involved at all.  15 mm socket/spanner on the retaining bolt and lever to the right (as you stand in front of the car) and ease the belt off all the pullies & out of the way. Start the engine & see if the noise has gone away. If so it's one of the auxillarues. If not it could be one of the cam belt tensioners, in which case you will need to delve deeper ASAP before the belt/tensioners give up & you need a 'new' engine' .... or 24 valves at the very least. :y
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #6 on: 21 September 2009, 22:18:09 »
Thanks guys. This is not something i feel i can do myself without messing up - i need to get someone to look at this (and a few other things soon). I am due to do a couple of 200 mile trips over the next 2 weeks so will keep my fingers crossed.
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #7 on: 21 September 2009, 22:23:48 »
in a 2.2  :question ;D
rustym95
« Reply #8 on: 21 September 2009, 22:26:10 »
well we will to but on safe side get RAC or AA etc, cose if it is somthing to do with cambelt u may need help to get home. finger crosed. [smiley=thumbup.gif]
« Reply #9 on: 21 September 2009, 22:29:10 »
You spotted my deliberate mistake then .......  ;D
I'd assumed there was a proper engine installed!!!
  ;) ;) ;) :y ;D
Radar
  • Berkshire
    • Elite 2.5 Auto
« Reply #10 on: 21 September 2009, 22:29:17 »
Thanks :y
rustym95
« Reply #11 on: 21 September 2009, 22:31:40 »
  ;) ;) ;) :y ;D
well it could have 24v might have some in the boot unever know lol
mantagte
  • great yarmouth
« Reply #12 on: 21 September 2009, 22:33:01 »
sorry andy coul'nt resist :y
« Reply #13 on: 21 September 2009, 22:33:07 »
A spare set of 8 in the glove box! lol ;D  ;D  ;D :y
rustym95
« Reply #14 on: 21 September 2009, 22:39:38 »
may have a spare car in there they are shrinking these days. lol ;D ;D ;D
