Author Topic: alarm problem  (Read 850 times)
jonny bv6 2003
alarm problem
« on: 17 August 2009, 21:28:41 »
had to  change the battery on my 2003 2.6 v6 cd miggy, now wen i connect the new battery the alarm sounds n the remote wont cancell it, help gettin stressed
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: alarm problem
« Reply #1 on: 22 September 2009, 01:04:54 »
bet u tuck your time puting in the bat's you only have 3mins to put new3 1z n after that you need the key to be setup gain as its lost its code. :(
Welung666
Re: alarm problem
« Reply #2 on: 22 September 2009, 05:52:34 »
My 2001 had the battery off for a while, had a couple of probs when re-connected but easy enough to sort.
Re-connect the battery (alarm may sound), open drivers door and switch ignition to #2 (red lights but don't start). leave it like that for a couple of minutes until the orange light (can't remember which of the two though) stops flashing. It should be ok and start then.
Page created in 0.01 seconds with 15 queries.
