Author Topic: aux belt tensioner advice  (Read 2464 times)
Richie London
  • heathrow
« on: 19 September 2009, 22:31:47 »
ihave to take mine off tomorrow, either to replace or just grease. do i need to take the cable tray off first. any tips or advice will come in useful.
RichB
  • Loughborough
Re: aux belt tensioner advice
« Reply #1 on: 19 September 2009, 22:34:08 »
I may be wrong but i'm sure when I did mine that I just took it off without removing any other parts, other that the belt of course  :y
Cheers,
Richard
« Reply #2 on: 19 September 2009, 22:42:57 »
As RichB says, just the belt to remove :y
Richie London
  • heathrow
« Reply #3 on: 19 September 2009, 23:47:37 »
cheers
« Reply #4 on: 20 September 2009, 01:03:43 »
...... any tips or advice will come in useful.
15 mm socket/spanner, anti clockwise.  ;)  ;)  ::)
Richie London
  • heathrow
« Reply #5 on: 20 September 2009, 09:22:34 »
15 mm socket/spanner, anti clockwise;)  ;)  ::)
thank god someone knows what there doing, i would have probably gone clockwise  ;D ;D ;D
kris
  • manchester
« Reply #6 on: 20 September 2009, 09:47:18 »
mines held on with 2 of them silly reverse torx bolts.  :-/ :-/
« Reply #7 on: 20 September 2009, 12:27:05 »
I was talking about the actual roller so you can remove the 'fan belt', the tensioner itself uses Torx head bolts.  :y
The seconday air pipe passes through the aux belt, so that has to be undone to get the belt off.  :y
« Last Edit: 20 September 2009, 12:28:57 by Andy_B »
kris
  • manchester
« Reply #8 on: 22 September 2009, 17:32:16 »
I was talking about the actual roller so you can remove the 'fan belt', the tensioner itself uses Torx head bolts:y
oh yeah. sorry :-[ :-[  ;D
  • Auckland
    • Mazda MPV
« Reply #9 on: 22 September 2009, 18:05:34 »
But... if you are keeping the old belt you can leave it hanging over secondary air pipe while you work on the idler.
« Reply #10 on: 22 September 2009, 18:31:06 »
Agreed!  :y
LFF64
  • HADDENHAM BUCKS
    • 64 insignia CT Nav 4x4
« Reply #11 on: 22 September 2009, 19:35:05 »
Well worth checking and doing as  I found out at Newent when mine seized up in the middle of the camp site  >:(
 But OFF to the rescue   :y
