Author Topic: Rattleing noise from top  (Read 1358 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
« on: 22 September 2009, 15:24:52 »
I've got a rattle which seems to be coming from the left hand side of my v6 ( possible camshaft area)
there is a slight cam cover leak so the cover is going to have to come off but this is worrying me.
Don't think it's the tapits ( to loud for that )
camshaft shells ???
Any ideas please
I first though it was the bottom so I dropped the sump this morning to find it clean ( no swarf on bits in there)
Re: Rattleing noise from top
« Reply #1 on: 22 September 2009, 15:31:14 »
could be a sticky lifter, how often is the oil changed?
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #2 on: 22 September 2009, 15:49:08 »
Last oil change only 1500 miles ago
but to be honest the oil did look pretty shitty when I dropped it this morning
before that f@ck knows ( last owner was supposed to be a mechanic / mot man from sLady bitshope but looking at the state of the top end rebuild he did I have got
my doubts )
sounds a bit too heavy unless it's stuck solid
Ps.    Pretty sure the previous owner is not on here
« Reply #3 on: 22 September 2009, 15:54:14 »
Just check the cam caps are tightened down (8Nm)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #4 on: 22 September 2009, 16:59:01 »
[size=16][/size]Its dead  :'(
left it running for a bit and things seemed to settle down so took it up the road for a very slow drive.
Picked our lass up and started back.
The car lost most of it's power.
Very little vacume on the brakes and sounded worse then ever.
Just about stopped the car on the hand brake outside my house.
I'm no mechanic but how does this sound ???  :'(
ps.   If there is a delay in answering it's because my pc went bang yesterday and I'm typing this on a chuffin I phone  >:(  >:(
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
« Reply #5 on: 22 September 2009, 21:34:13 »
Cam cover off
swarf around the middle set of cams
cams look in one piece
seriously confused now
« Reply #6 on: 22 September 2009, 21:36:37 »
Post some pics
