Author Topic: abs ecu question  (Read 1160 times)
jb1kenoby
abs ecu question
« on: 30 September 2009, 17:57:13 »
i have just bought a s reg mv6 estate and the only main problem is that the abs ecu is shot on it and i was just wondering if the one of a 2.5 cdx on a p reg would fit ????
if not does any one have one knocking about as i want to get it sorted asap but dont want to pay autovaux or vauxhall prices
3.2 manual
  • nr yeovil, somerset
  • the great thread ender! whoops
Re: abs ecu question
« Reply #1 on: 30 September 2009, 18:24:14 »
might be worth taking the shot one to a scrappy, compare the part number to other vaux 97 models. if the numbers are the same, it may not even have to come from an omega. my clutch switch is out of a vectra, cruise stalk from a senator. they use common parts a lot of the time.
oh bugger, i thought that was a bit of wind!!!
jb1kenoby
« Reply #2 on: 30 September 2009, 18:32:50 »
ive been told the part numbers are
for the complete assembly   9192236
just the control unit             9117171
or from bosch its                1 273 004 206
but not sure what else they fit
« Reply #3 on: 30 September 2009, 18:48:26 »
In a word, No.
the P reg will be the older 3 channel setup, your S reg will be the later (and less reliable) 4 channel setup.
If it was the same, would need its config updating as well as the ecu's know engine size and transmission too....Not an issue for this one obviously, but may be a consideration on other 2nd hand modules  :y
jb1kenoby
« Reply #4 on: 30 September 2009, 18:50:48 »
thanks for that saves trying it tomorrow
all i need to do know is try and find one :(
dont surpose any one has got one
i would put up a wanted post but it wont let me :(
