Author Topic: speedo not working  (Read 1736 times)
itonks
  • Cannock, staffordshire
speedo not working
« on: 03 October 2009, 22:09:38 »
Hi hope someone can help abs light one traction control light on and speedo stopped working, read up on this lots of different answers :-? If it is the abs control unit attached to the pump do i need to get it reset if a second hand one is fitted , does the second hand one need to have the same two letter code on the top? can anyone help plz  :)
Welung666
Re: speedo not working
« Reply #1 on: 03 October 2009, 22:12:52 »
Welcome aboard Itonks :y If you get a replacement it must be from a similar age and the exact model (I.E. 2.5 CDX manual) or it will need a Tech2 to be re-programmed and they aren't cheap. The alternative it to send it off to a company calle BBA Reman (google them), they will re-con yours for around £110 and guarantee it unlike a 2nd hand unit :y HTH
itonks
« Reply #2 on: 03 October 2009, 22:18:36 »
Thanks Ive been offered on of a 02 car same model 2.5 CDX auto cheap (mine is a X reg) but two code letters on top different will this matter?
« Reply #3 on: 03 October 2009, 22:21:55 »
Are you sure it`s a 2.5 and not a 2.6
itonks
« Reply #4 on: 03 October 2009, 22:25:23 »
Only what ive been told not seen the car myself yet its in a friends scrap yard
« Reply #5 on: 03 October 2009, 22:26:00 »
2.5 was not in 2002 year, only 2.6, not sure if the ABS ECU's are swappable between the 2  :-/
« Reply #6 on: 03 October 2009, 22:27:07 »
If it`s on an O2 plate it`s going to be a 2.6 so will need a chat with Tech II
Fill in your profile as to location etc. May be somewhere near with Tech II
« Last Edit: 03 October 2009, 22:29:01 by RobG »
« Reply #7 on: 03 October 2009, 22:27:57 »
Slipping in just ahead of me again Tunnie ;D
Welung666
« Reply #8 on: 03 October 2009, 22:28:46 »
It'll be a 2.6, as long as it's cheap enough then get it but you'll need it Tech2'ing and I think Kevin will be your closest (although that depends where in the big smoke you are).
itonks
« Reply #9 on: 03 October 2009, 22:31:02 »
Thanks will try and let you know what happens also does anyone know where to get a code for a ccr2006 and do you need two one for radio and one for cd or just one.
« Reply #10 on: 03 October 2009, 22:33:22 »
  • Auckland
    • Mazda MPV
« Reply #11 on: 03 October 2009, 22:37:44 »
Have you have just bought the car? With luck you will find the 'car pass' in the owners handbook. The code for the original radio will be on this card.
itonks
« Reply #12 on: 03 October 2009, 23:08:53 »
Second hand radio out of the car in the yard no paper work with the car, therefore no hope of the car pass :'(
  • Auckland
    • Mazda MPV
« Reply #13 on: 03 October 2009, 23:27:34 »
As RobG suggested then. Contact DaveDND before entering too many wrong codes and locking it up totally.
