Author Topic: Autobox refurb  (Read 776 times)
Gaffers
  • NE Hampshire/Surrey
    • Ford Ranger Wildtrak
Autobox refurb
« on: 05 October 2009, 11:54:58 »
I am in the process of refurbing a spare AR25 I have in the garage.  Initial inspection of the sumps show no broken thrust washer (sweet!) so I am about to put an order into JPAT for the spare I will require.  I have looked on the website and I am just a little confused that I will be ordering the right parts:
-Pickup filter - 209 27 01
-Thrust washer (dont know if steel or bronze is best) - 120 22 01 / 120 22 02
The How-to talks about various O rings and gaskets being replaced but I am not sure which ones he means.
Has anyone done this who can check if I have the right part numbers and if the bronze or steel Thrust washer is best?
Re: Autobox refurb
« Reply #1 on: 05 October 2009, 11:57:15 »
think mine was bronze  :-/
there is a large paper gasket you want as well, about 50p
are you getting sump gaskets, or using instant stuff?
Iirc, I just mailed them saying I had an AR35, wanted gaskets, filter, thrust washer, paper gaskets, and they specced it up.
ill try and dig out the order....
Re: Autobox refurb
« Reply #2 on: 05 October 2009, 12:00:30 »
N209 25 01 GASKET, FRONT PAN, GM 4L30E, BMW, VAUXHALL 1.00 5.85 50.00 2.92 1
N209 25 02 GASKET, REAR PAN, GM 4L30E, VAUXHALL ONLY 1.00 6.39 50.00 3.19 1
N209 27 01 FILTER, GM 4L30E, AR25, VAUXHALL 44mm 1.00 21.01 50.00 10.50 1
I havent got an electronic copy of the other bits sorry, they were tagged on afterwards
Re: Autobox refurb
« Reply #3 on: 05 October 2009, 12:02:42 »
Thrust was £19.63 apparently, dunno if this was before or after discount though, think after....
Gaffers
Re: Autobox refurb
« Reply #4 on: 05 October 2009, 12:03:13 »
Cheers bud :y
