Author Topic: 2.5 v6 oil leak  (Read 1198 times)
ange4631
  • herts
2.5 v6 oil leak
« on: 05 October 2009, 13:12:46 »
i changed split rad after overheated slightly, along with cam cover gaskets, and cleaning the breather pipes/assembly on top of plenum.  problem is now an oil leak that only appears with engine running and runs down the drivers side of the auto box housing (had a look in the bell housing and no oil leak present there).
upon further inspection it seems that the leak is from further up, any help would be great!!
was also running lumpy after re-assembly, but im pretty sure that it needs new leads due to the cam cover gasket problem!! cheers!!
Re: 2.5 v6 oil leak
« Reply #1 on: 05 October 2009, 13:15:11 »
did you get the half moons in place at the rear of the cam covers, black sealant used as per the guide?
ange4631
  • herts
Re: 2.5 v6 oil leak
« Reply #2 on: 05 October 2009, 13:18:20 »
yes to both, and no oil there afterwards!
