Author Topic: 3.0 MV6 Exhaust gaskets  (Read 1169 times)
grijander
« on: 05 October 2009, 10:55:58 »
I'm going to change complet exhaust from manifold(excluded).
And the unic gasket sended to me from supplier is a kind of ring that think goes between manifold and cat. is it right?
On the other hand I have no gasket between cat and central exhaust. is it right?
Just in case, what kind of gasket are the correct ones in order to make a perfect job?
Any recommendation like the black grease(molibdeno) to the lambda thread?
Thanks in advance.
Re: 3.0 MV6 Exhaust gaskets
« Reply #1 on: 05 October 2009, 11:00:19 »
correct, gasket at manifold to downpipe (cat) join.
no gaskets further on, just use exhaust paste to ensure a good join  :y
grijander
« Reply #2 on: 05 October 2009, 19:32:48 »
Ok, and regarding bolt's threads, what do you think? is it also useful to put that black grease on, or better to put some locker liquid to block them from vibrations?
Ian_D
  • York
« Reply #3 on: 05 October 2009, 19:48:33 »
I cant see the bolts vibrating free, that said stranger things have happened!  ;D
Does anyone know the part no for the manifold to cat gasket? as I need two  :'(
[size=12]
grijander
« Reply #4 on: 05 October 2009, 21:14:32 »
piece nš 24436627 for X30XE
