Author Topic: mid and engines  (Read 1709 times)
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
mid and engines
« on: 13 October 2009, 10:11:41 »
currently have a 2.5 v6 manual pre mod estate
205/65/15  wheels and tyres
soon to have a 3.0 lump fitted  ;D ;D :y
do i need to change the mid for one off a 3.0 to keep the readings true ?
or will they be ok  :y
( providing i keep the wheel / tyre ratio the same  :y
ie  215/ 55/16 ........... 225/45/17 ............. blah blah blah
cheers   steve
Re: mid and engines
« Reply #1 on: 13 October 2009, 10:24:10 »
you can just have the config changed on yours to match the new engine  :y
will need a chat with tech2
Re: mid and engines
« Reply #2 on: 13 October 2009, 10:28:20 »
Not sure as it will need changing as the tyre size is not changing and its still a V6 (trying to remember the config!)
Re: mid and engines
« Reply #3 on: 13 October 2009, 10:49:03 »
abs ecu will want to know the engone size has changed as well
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: mid and engines
« Reply #4 on: 13 October 2009, 10:50:45 »
oh bugger  :(
tech 2 programable ?
Re: mid and engines
« Reply #5 on: 13 October 2009, 10:59:43 »
oh bugger  :(
yes  :y
Re: mid and engines
« Reply #6 on: 13 October 2009, 11:04:10 »
Not disputing you Jim ...... why's that?
Re: mid and engines
« Reply #7 on: 13 October 2009, 11:06:52 »
havent a clue.
but it DOES know engine size and gearbox type.
guess you will get error codes / incorrect operation of some sort.
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: mid and engines
« Reply #8 on: 13 October 2009, 11:09:18 »
it will have cruise fitted  :y
at least when i get round to sorting out the pedal switches out  :-[
any diferance ?
Re: mid and engines
« Reply #9 on: 13 October 2009, 11:11:13 »
slightly related....when my ABS ECU was replaced, with a BRAND NEW one, it had no config.
this caused TC light to be always on, and also caused the car to stall when idling for about 2 minutes after starting the car if the revs werent kept up.
programming the config solved both instantly.
engine note changed as well when the config was set.
black magic at its best!
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
Re: mid and engines
« Reply #10 on: 13 October 2009, 11:42:59 »
this one should still have the 2.5 settings in so i'll see how it goes for now  :y
just want my car back  >:( >:(
been 22 days upto now  >:(
Re: mid and engines
« Reply #11 on: 13 October 2009, 20:32:58 »
yeah, its different between otherwise identical 2.5 and 3.0
Page created in 0.024 seconds with 16 queries.
