Author Topic: EXHAUST QUESTION  (Read 879 times)
capoMV6
EXHAUST QUESTION
« on: 15 October 2009, 03:07:18 »
My MV6 still has the standard exhaust. Can I divide the exhaust to install a dual exhaust pipe at the end? What would be the effect?
rustym95
  • Rotherham south yorks
  • carn't get up dont go out!!
Re: EXHAUST QUESTION
« Reply #1 on: 15 October 2009, 07:28:59 »
would think you would lose power, has to be a proper systerm, seen some car done that way and not good on hills at all. :y
Welung666
« Reply #2 on: 15 October 2009, 08:32:44 »
Before you even start to worry about power loss etc., you have the logistical problem of the fuel tank being in the way. You'd have to fit a short length in where the backbox normally starts and route it around the back of the fuel tank with the appropriate heatshields. Then make the turn to head out of the back. Probably easier with a straight through pipe and do away with the backbox all together.
« Last Edit: 15 October 2009, 08:33:02 by Welung666 »
