Author Topic: cool running thermostat?  (Read 5030 times)
kingplym
  • camden, hatfield, st.neots
  • sports on, kick down
« on: 21 October 2009, 22:32:55 »
as above is there any point in installing a cool running thermostat like those from the vauxhall specific tuning centres? :-?
i am willing to trade my electrical labour for parts work etc
serek
  • huntingdon
    • 3.2 mv6
Re: cool running thermostat?
« Reply #1 on: 21 October 2009, 22:43:17 »
 there is no room for any different tape of thermostat
« Last Edit: 21 October 2009, 22:45:38 by serek »
kingplym
« Reply #2 on: 21 October 2009, 22:48:01 »
is it not just a straight swap out for a stat that opens a earlier? :-? :-? :-?
kingplym
« Reply #3 on: 24 October 2009, 15:15:49 »
is the thermostat on the 3.0 the same as the 2.5? i ask cos i want to install a cool running stat. while at tesco's i have just seen in the total vauxhall mag in the back pages the guys from the mag rebuilding a 3.0 v6 and installing a cool running stat from a xe? what is this xe? (they were also adding a supercharger!!!)if anyone can help me with this, the stat, i would appreciate it as i would like to do what i can to bring the running temp of the engine down everyway possible :y :y :y
« Reply #4 on: 24 October 2009, 15:21:12 »
a 'cool' running stat is not going to make any significant improvment in performance, it will just waste fuel
« Reply #5 on: 24 October 2009, 16:50:35 »
I dispair with some of these modifications that these so called 'performance' companies sell.
A cool running stat wont do jack.
And engines temp is far more to do with the cooling capability of the rad and the 92-93 DegC setting for the standard setup gives a pretty much ideal setup for this power unit
Martin_1962
« Reply #6 on: 24 October 2009, 18:01:21 »
The V6s prefer to run warm - a waste of time
kingplym
« Reply #7 on: 24 October 2009, 18:23:49 »
im not looking to improve the performance i would just like me migger to run a bit cooler as occasionally esp in stop start traffic the temp goes up to 100 with fans working.
the  cooling system has been flushed. so should i think about trying a new standard stat and new radiator?
on motorways and long drives the temp sits just above 92 rarley rising to 95 so maybe im being a drama queen? :-[ ::)
any help please :y
« Reply #8 on: 24 October 2009, 18:26:00 »
as long as it does not go past 100 you will be fine.
kingplym
« Reply #9 on: 24 October 2009, 18:33:47 »
ahh there in lies the problem which is rattling me as it does nudge over the 100 bar  :(
after being on A1 getting into london the temp spike intermittently often pushing past 100 for 5-10 mins before coming down when i move but when i sit again temp begins hunting for 100 again :-?
so im thinking now i should just buy and fit new stat and rad cos this will keep bothering me knowing i could do something about it >:(
« Reply #10 on: 24 October 2009, 18:37:27 »
could be a sticking stat, replace with a standard GM one.
kingplym
« Reply #11 on: 24 October 2009, 18:39:38 »
ok ill get onto it asap :y thanx for the advice tunnie :y :y
Abiton
« Reply #12 on: 24 October 2009, 18:59:14 »
If the problem is only really occurring when stationary or in slow-moving traffic, surely your first port of call should be to ascertain 100% that your radiator fan(s) are doing exactly what they are supposed to be.
You'd be well hacked off if you went to all the trouble and expense of buying/fitting thermostats and radiators that made no difference at all.
kingplym
« Reply #13 on: 24 October 2009, 19:26:53 »
the fans do work and they do all three of them! i seen the blast of air clear a puddle from under the car before!
when i got my migger end of march it had been sitting since last sept and when i drove it at first it constantly overheated after flushing this stopped but im concerned that maybe the rad isnt fully flushed/has a severe blockage,  so if i get a new one i at least know that is no longer an issue :)
« Reply #14 on: 24 October 2009, 20:42:26 »
If it is running hotter than normal then fix the problem rather than fitting a cooler stat. Both the original and cool stats will be fully open at 100 degrees c - so how is it going to help?
Bear in mind that you won't have a problem until 115-120 degees C because the boiling point of the coolant is raised both by the antifreeze and the pressure in the cooling system.
