Author Topic: Can't identify Leak.  (Read 1030 times)
davethediver
  • Blackburn, Lancs.
« on: 25 October 2009, 12:51:40 »
Hi guys was changing the oil this morning and noticed a small leak under the car :'( seems to be worse when car is running. It looks as if its coming from inbetween the wo sump pans of the autobox. It looks as though there are two pipes running above them and leak seems to be from that area!
Liquid appears to be clear anybody got any ideas :question
TAI Dave
P.A. Caron de Beaumarchais
Welung666
Re: Can't identify Leak.
« Reply #1 on: 25 October 2009, 13:39:59 »
If it's clear it's either rainwater or coolant. Check your coolant level and have a feel around the HBV for wet pipes ;) :y
« Reply #2 on: 25 October 2009, 15:24:50 »
air con drains, normal. :-)
hotel21
  • The Kingdom of Fife
« Reply #3 on: 25 October 2009, 15:29:05 »
As Chris says, most likely the aicon condensate drain.  Switch off the aircn and take the car for a drive for a couple of miles to ensure the engine block has dried off and recheck for the 'leak'.  Switch on the aircon again and, if guesses are correct, the 'leak' will reappear....   :y
davethediver
  • Blackburn, Lancs.
« Reply #4 on: 25 October 2009, 16:49:34 »
Thanks guys i think it may well be the aircon drain as it looks like a small drain is just above the two pipes will check it again when its not as wet as today. All fluid levels appear to be ok so hopefully its just a drain.
Thanks again. :y
