Pages: 1 [2] 3  All   Go Down
Author Topic: my 2002 omega 2.2 petrol is in limp mode  (Read 4242 times)
bushwacker
  • wolverhampton
Re: my 2002 omega 2.2 petrol is in limp mode
« Reply #15 on: 03 November 2009, 22:33:40 »
ok but when it isent in limp mode the gearbox is fine does that mean anything?
« Reply #16 on: 03 November 2009, 22:35:08 »
Does it rev over 4k rpm? Assuming not as you said its in limp mode. Can still be the gearbox, its like a safe mode for it.
bushwacker
  • wolverhampton
« Reply #17 on: 03 November 2009, 22:38:22 »
yes it can rec  to that quite easy untill it goes into limp mode ...also how would i tell if the cam sensor has been changed in my service book?
Ken T
  • Stockport
« Reply #18 on: 03 November 2009, 23:09:16 »
One advantage with the 4 pots is that if the cam sensor goes, the car will keep going, only at reduced speed. On the V6's, the engine dies and that's it.
Changing it is fairly easy, if I remember its at the front of the engine just under the belt cover.
To accurately diagnose it you need a Tech 2 or a good code reader (not the Elm 327 ones) there were some cheap chinky ones on fleabay, that were a copy of a moderately expensive one, but we don't talk about them..............
Ken
davethediver
  • Blackburn, Lancs.
« Reply #19 on: 04 November 2009, 00:52:07 »
Any half decent code reader should give you the codes, sounds very similar to what happened with mine, would drive ok then just not rev past a certain amount no matter how much i floored it. Changed sensor and hey presto all fine now.
As said before i think part was about 60 quid. But someone local may pop over and read codes for you, don't start spending money on changing parts till your sure thats what it is :y
P.A. Caron de Beaumarchais
Welung666
« Reply #20 on: 04 November 2009, 06:08:16 »
Bushwacker, I'm only in Dudley and can read/clear the codes for you. If it proves to be the crank sensor (as I also believe it is) then I'll talk you through changing it too :y
bushwacker
  • wolverhampton
« Reply #21 on: 04 November 2009, 13:59:44 »
welung666 did you get my pm?
Welung666
« Reply #22 on: 04 November 2009, 14:10:02 »
Yes matey :y I'll give you a bell later this afternoon :y
portomega
  • Port Talbot, S. Wales
« Reply #23 on: 04 November 2009, 14:44:44 »
i seem to have the same problem with my 2.2 , but only seems to go into limp mode when the engine is started and its hot if i start the car when the engine is cold it will start fine.....is that a sign of the cam sensor going?
davethediver
  • Blackburn, Lancs.
« Reply #24 on: 04 November 2009, 14:47:59 »
Do you get any warning lights on the dash, would advise getting the codes read better safe than sorry :y
ajn
  • cardiff
« Reply #25 on: 04 November 2009, 15:56:10 »
hello i had this problem with my 2.2 auto turned out to be as tunnie said my selector switch on the side of the gearbox,changed it with one i bought off one of the lads on here no more limp mode or spanner light on dash have you noticed the lights on the side of the gear lever (p 1 2 3 d r) flashing or all on if so could be your problem ajn
bushwacker
  • wolverhampton
« Reply #26 on: 04 November 2009, 18:09:22 »
SO IS THE SELECTOR SWITCH ON THE SIDE OF THE GEARBOX THE SAME AS THE CAM SENSOR OR NOT ? ?
Welung666
« Reply #27 on: 04 November 2009, 18:21:17 »
No nothing alike matey, your phone's gonna ring any second ;) :y
bushwacker
  • wolverhampton
« Reply #28 on: 04 November 2009, 18:40:46 »
just like to say a big thanks to all the advice ive recived already
and welhung666 thanks for the call i hope i can sort this out soon ! ! :'(
bushwacker
  • wolverhampton
« Reply #29 on: 04 November 2009, 19:00:23 »
just a note to the lads who asked if the gearbox lights are flashing or sticking on ....so i just took it out.. no flashing lights on the gearbox or lights sticking on the gearbox just the one with the spanner through??
Pages: 1 [2] 3  All   Go Up
