Pages: [1] 2 3  All   Go Down
Author Topic: my 2002 omega 2.2 petrol is in limp mode  (Read 4245 times)
bushwacker
  • wolverhampton
« on: 03 November 2009, 21:53:57 »
first of all hi to you all ime new to this site ...
ok my omega has the light with the spanner on . and keeps going into limp mode any help please it driveing me up the wall ive got to go 80miles on thursday and ime worried about this
Re: my 2002 omega 2.2 petrol is in limp mode
« Reply #1 on: 03 November 2009, 22:01:27 »
2 main things cause limp mode, gearbox, or cam sensor.
Most likely its the cam sensor, can you get the codes read?
Update your profile with your location, someone near you may have tech2
« Last Edit: 03 November 2009, 22:01:49 by tunnie »
bushwacker
  • wolverhampton
« Reply #2 on: 03 November 2009, 22:06:47 »
oh ok does the cam sensor cost ££££££££ ..and how do i update my profile sorry to be a pain ...and ime in wolverhampton
« Reply #3 on: 03 November 2009, 22:09:04 »
User CP > Profile > Edit Profile
Cam sensor is not expensive, think its around £60ish? can't remember.
Easy as pie to replace, go for genuine part, pattern have had a poor history for this.
Get codes read before you go replacing parts though  :y
« Last Edit: 03 November 2009, 22:09:23 by tunnie »
mathewst
  • Split, Croatia
    • v40
« Reply #4 on: 03 November 2009, 22:09:07 »
Cam sensor is around 60 pounds.
you must buy original part, aftermarket ones don't work on 2.2
bushwacker
  • wolverhampton
« Reply #5 on: 03 November 2009, 22:19:54 »
is there anyway i can do a quick fix just to the weekend as i need it thursday
mathewst
  • Split, Croatia
    • v40
« Reply #6 on: 03 November 2009, 22:22:59 »
car could  work normally from time to time.
But it is 10 minute work to change the cam sensor if that is wrong.
See if anyone can get the codes read first.
How many miles has the car got on clock?
« Reply #7 on: 03 November 2009, 22:24:41 »
Cam sensor either works or it doesn't, like i say you need to read the codes. Cam sensor is just one possible cause, the gearbox could be giving a code causing same symptoms.
Closest tech2 to you is Brackley (NN13)
Do you have a laptop? Can get a 'cheapo' tech2 off eBay
bushwacker
  • wolverhampton
« Reply #8 on: 03 November 2009, 22:24:46 »
car has done 150000 full vauxhall servlice history
« Reply #9 on: 03 November 2009, 22:26:07 »
Good miles, keep on top of those coolant changes  :)
mathewst
  • Split, Croatia
    • v40
« Reply #10 on: 03 November 2009, 22:26:48 »
Well cam sensor usually lasts around 100 000 or a little more so it probably is dead.
Can you check on service history has it been changed anytime in the past?
bushwacker
  • wolverhampton
« Reply #11 on: 03 November 2009, 22:28:24 »
ok at least ive got an idea thanks lads
mathewst
  • Split, Croatia
    • v40
« Reply #12 on: 03 November 2009, 22:29:46 »
Is the car auto or manual?
bushwacker
  • wolverhampton
« Reply #13 on: 03 November 2009, 22:30:18 »
auto
mathewst
  • Split, Croatia
    • v40
« Reply #14 on: 03 November 2009, 22:31:53 »
So it also could be the gearbox.
Unfortunately you need the codes read
Pages: [1] 2 3  All   Go Up
Page created in 0.171 seconds with 16 queries.
