Author Topic: Sticky Control Knobs  (Read 1224 times)
John_Clayton
  • Great Chart, Ashford, Kent
    • 1998 2.5 V6 Tourer
« on: 04 November 2009, 14:35:11 »
When the weather's wet, or even slightly damp, the knobs for the climate control get all sticky. This makes them very unpleasant to use. Can anyone recommend a good cleaner - or other solution - as I've had no success with the ones I've tried so far?
John Clayton
Re: Sticky Control Knobs
« Reply #1 on: 04 November 2009, 14:38:06 »
Well thats a new one!
I find baby wipes good at removing all sorts.
any idea what is making them sticky?
wd40 can remove sticky stuff, depending what it is, dunno if it would have any effect on printed bits though
« Last Edit: 04 November 2009, 14:39:24 by jimbob »
mathewst
  • Split, Croatia
    • v40
« Reply #2 on: 04 November 2009, 14:57:53 »
Use glass cleaning liquids.
I had the same problem and nothing helped untill one of my uncle's workmen recomended it to me (and they do the new furniture sale and assembly)
But you must remember to after cleaning with glass liquid shampoo wipe it again with slightly wet rags
« Reply #3 on: 04 November 2009, 23:47:09 »
It's that poxy rubberised finish VX used, if the car interior is slightly damp the control buttons do sometimes feel 'tacky'. I reckon the glass cleaner tip sounds good as it's not so aggressive a cleaner. :y
« Reply #4 on: 05 November 2009, 06:09:24 »
not on a 97 omega.....
John_Clayton
« Reply #5 on: 05 November 2009, 12:36:27 »
Do you mean that rubberised finish wasn't used, or I shouldn't use the glass cleaner?
John Clayton
mathewst
  • Split, Croatia
    • v40
« Reply #6 on: 05 November 2009, 12:48:37 »
He means the finish.
You can use glass cleaner.
I used it on mine without problems, and it was the only thing that worked.
just remember to wipe the plastic with some rags which were soaked in water afterwards to remove all of the residue of glass cleaner from plastic
cruisetopoland
  • UK
« Reply #7 on: 05 November 2009, 13:11:47 »
Yeah-one nasty feature of the Omega.
Will try glass cleaner, cheers  :y
