Author Topic: Smoky exhaust on pull away  (Read 1443 times)
baz1701
« on: 09 November 2009, 18:32:31 »
Only noticed int he last day or so but the exhaust is pretty smoky on pulling away from standstill. Once it's above 25 miles an hour it becomes fine, but it's a bit of a worry.
Any ideas?
hotel21
  • The Kingdom of Fife
Re: Smoky exhaust on pull away
« Reply #1 on: 09 November 2009, 18:36:29 »
More than likely its condensate, given the lower outside air temperatures.  Once the cat(s) is at temp then it does reduce, although water is a by product of good combustion, as I recall....  :y
« Reply #2 on: 09 November 2009, 18:38:09 »
Yup as H21 says.  Omegas do produce a lot of moisture, particularly when cold
baz1701
« Reply #3 on: 09 November 2009, 18:42:16 »
Thanks for the advice.
Was a bit worried about getting pulled by the cops that's all, it does look a bit like a steam train on first starting!
unlucky mark mv6
  • tipton,west mids
« Reply #4 on: 09 November 2009, 19:54:22 »
Noticed mine was a bit smokey last winter when i had mine,and come the summer i had nothing,but now the cold weather is back again this year its the same again,so obviously is condonsdate,as it does not use a drop of oil or anything.
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #5 on: 09 November 2009, 19:57:10 »
If the Cops are following you, put your foot down be a steam screen so they wont see you whizz off.. bit like James Bond stuff ;) ;D :D
