Author Topic: code 19- td  (Read 1731 times)
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
code 19- td
« on: 13 November 2009, 11:14:20 »
code 19 - incorrect rpm signal. this code has popped up on a pc test. can somebody please enlighten me of the cause & cure . thankyou. :)
7
batista
  • yardley wood birmingham
Re: code 19- td
« Reply #1 on: 13 November 2009, 16:35:13 »
i thought code 19 is crank sensor,, :-/ i may be wrong
Pitchfork
  • Tadley (near Basingrad)
  • Barndances & Morris
Re: code 19- td
« Reply #2 on: 13 November 2009, 17:20:13 »
Remember it's a Weazle!!
Do Traktors have different codes?
Re: code 19- td
« Reply #3 on: 13 November 2009, 17:25:54 »
all Diesel codes here...
http://www.omegaowners.com/forum/YaBB.pl?num=1205270870
so yes, crank sensor
raywilb
    • Citroen C4 Cactus
Re: code 19- td
« Reply #4 on: 13 November 2009, 17:58:21 »
my tractors starting & running ok, can i expect it to nack up, & where is the crank sensor situated. ?  :y
damage consultant
  • falkirk (sunny scotland)
Re: code 19- td
« Reply #5 on: 13 November 2009, 18:50:44 »
i'm sure the crank sensor job is a front end off job correct me if i'm wrong though :-/.
Try putting a 6mm earth direct from battery to ecu and see if it runs any better.
« Last Edit: 13 November 2009, 18:52:37 by senny »
Re: code 19- td
« Reply #6 on: 13 November 2009, 19:18:11 »
if it is the sensor, it can be done from underneath, but easier to remove intake and starter...
raywilb
    • Citroen C4 Cactus
Re: code 19- td
« Reply #7 on: 13 November 2009, 19:54:44 »
i had the intake & starter off last weekend could i have disturb something.
Omegatoy
  • UK
Re: code 19- td
« Reply #8 on: 13 November 2009, 20:26:10 »
crank sensor is just the starter motor aND FIDDLING AROUND doing starter IT MAY BE POSSIBLE TO KNOCK THE CONNECTOR  although it does have a clip you have to push to release it, more likely that you have leant or levered against it without knowing and damaged or dislodged the connection
