Author Topic: Vacuum operated heater controls?  (Read 1138 times)
Blackie_No1
  • Ballyclare N.Ireland
    • Omega Elite 2.5
« on: 08 November 2009, 20:00:40 »
Basically the heater is stuck pointing at the windscreen, nothing changes when I turn the dial, the diagram in haynes ain't much help as I can't find where the main vacuum feed comes from?
2000 Omega Elite 2.5 V6
Abiton
Re: Vacuum operated heater controls?
« Reply #1 on: 08 November 2009, 21:16:02 »
As far as I recall, if you delve around above the pedals in the drivers footwell, you'll find where the alloy heater-matrix pipes come through the bulkhead.  In amongst them, you'll find one or two vacuum hoses coming from/going to the engine bay.
The yellow* one of these is the source of the vacuum that is used to power the various flaps that direct the airflow in the cabin.  It has possibly become disconnected at the point where it comes through the bulkhead.
*Check colours against what Haynes says, my memory ain't what it once was.
Hope this helps.  :)
Blackie_No1
    • Omega Elite 2.5
« Reply #2 on: 08 November 2009, 22:32:57 »
Sweet mate, will be looking at that tomorrow night
« Reply #3 on: 09 November 2009, 08:39:12 »
Forget the drivers foot well for the time being, concentrate on the engine bay vac pipes, its an order of magnitude more likely that this is where the likely cause will be.
Check for disconnected pipes and damaged pipes.
Also, please state if you have manual controls or climate control.
Blackie_No1
    • Omega Elite 2.5
« Reply #4 on: 09 November 2009, 19:28:30 »
Manual controls, I did check and found a few disconnected pipes, but there wad no vacuum felt when the engine was running, a wee silly one that runs to some sort of actuator located just behind the radiator
Blackie_No1
    • Omega Elite 2.5
« Reply #5 on: 15 November 2009, 09:07:38 »
Abiton your a star, that's exactly what it was, the yellow hose was not connected
Abiton
« Reply #6 on: 15 November 2009, 11:20:18 »
Glad I could help.  :)
