Author Topic: folks not  (Read 1557 times)
medwaykent
folks not
« on: 23 November 2009, 20:11:25 »
hi  not long joined as recently purchased omega elite which is great apart from couple of probs which i hope someone can help me with firstly resistor had blown so replaced ,fan now working but no hot air just cold do you think matrix is blocked or could it be something else ...secondly remote fob works a couple of times when programed then wont and alarm goes of when unlocking door with key and you have to put key in ignition quickly to stop horn is the fob faulty or is it something more sinister !!!!!! thx in advance. :o paul
Re: folks not
« Reply #1 on: 23 November 2009, 20:14:08 »
Need a little more info:
1) Engine, petrol diesel?
2) Age?
3) Specfication?
Welung666
Re: folks not
« Reply #2 on: 23 November 2009, 20:15:23 »
Heat problem - check the vacuum hose is still on the HBV (black starship enterprise looking thing behind the drivers side head. Vacuum pipe comes up off the top).
Remote fob - which type is it? Seperate remote or in the key? Could be the battery holder loose or the microswitches. Speak to MartinImber on here, he reconditions the remotes :y
As for the alarm going off, rech round from the drivers side rear door and push the button down on the drivers door. this locks the car without arming the alarm BUT MAKE SURE YOU HAVE YOUR KEYS IN YOUR HAND! ;)
medwaykent
Re: folks not
« Reply #3 on: 23 November 2009, 21:05:30 »
hi again the car is omega elite 3.0 v6 1996
medwaykent
Re: folks not
« Reply #4 on: 23 November 2009, 21:07:02 »
and the fob is independant of key with two buttons on it
medwaykent
Re: folks not
« Reply #5 on: 24 November 2009, 18:19:28 »
have checked vacuum pipe its on there ok ....as there is no heat what so ever coming through blowers but both pipes going into car to heater matrix appear hot will it be heater matrix blocked ? :-/
Welung666
Re: folks not
« Reply #6 on: 24 November 2009, 18:29:47 »
Try backflushing it, take both hoses off and run a hose pipe through each pipe in turn until the water runs clear. Re-attach the pipes and refil the system with fresh anti-freeze :y
Matchless
  • Nottingham
    • A white van
Re: folks not
« Reply #7 on: 24 November 2009, 23:06:47 »
Both heater hoses are hot which suggests that you have water flow through the matrix so the problem lies with the air blending flaps or their controls.
Try resetting the climate panel, ignition on, press and hold 'auto' and 'off' until you hear the servo motors start whirring. Wait till it finishes then see if there is any improvement.
When you turn off the ignition are there any 'dashes' on the climate temp displays?
Page created in 0.034 seconds with 16 queries.
