Author Topic: Small Plastic Tubes?  (Read 1670 times)
Drewomega
  • Aviemore and Mallorca
    • SKODA Octavia Scout 2.0
« on: 02 December 2009, 13:27:12 »
Could someone tell me what the two small tubes shown going from a black box-like thing near the alternator and running diagonally from lower left to upper right and disappearing into the back of the engine near the bulkhead? The reason I am asking is, one of the tubes I have is open ended at the bulkhead end. Is this correct? Thanks.  :-/
http://www.omegaowners.com/forum/YaBB.pl?num=1176213776
I'm always last in the office in the morning but I make up for it by leaving first.
Re: Small Plastic Tubes?
« Reply #1 on: 02 December 2009, 13:29:24 »
They are the vacuum pipes, without it you wont have working multirams...
so your car will not be running as it should.
the layout diagram is here :
http://www.omegaowners.com/forum/YaBB.pl?num=1152565204
« Last Edit: 02 December 2009, 13:29:44 by jimbob »
Drewomega
« Reply #2 on: 02 December 2009, 13:35:35 »
Wow! JimBob, a really quick reply. I can't quite see where the open ended tube goes though. I need a torch I think. Thanks.  :y
Drewomega
« Reply #3 on: 02 December 2009, 14:01:29 »
JimBob! I still cannot find where the open end goes! It is the one with the T-piece off it. I have found the other tube, it goes to the near side bulkhead piping.
Drewomega
« Reply #4 on: 02 December 2009, 14:28:36 »
Job Done! Many thanks.  :y
« Reply #5 on: 02 December 2009, 14:30:36 »
cool, you found the hole  :y
always a struggle finding small holes in the dark  ::)  :y
« Reply #6 on: 02 December 2009, 14:49:22 »
Its easy, just follow your nose  :y ;D
Drewomega
« Reply #7 on: 02 December 2009, 19:45:22 »
On a footnote on the dark hole business! would me connecting the said open ended pipe into the hard to find orifice make a difference to my heating? Because my heating system seems a lot more efficient as it were!  ::) :D :y
hotel21
  • The Kingdom of Fife
« Reply #8 on: 02 December 2009, 19:48:42 »
Yup.........  its the vacuum connection to the heater & vents!      ;)
